1.1 Manual errors
  • safl
    • May 2005
    • 103
    1.1 Manual errors
    Hey!
    There seems to be error's in the online manual here:
    http://www.zabbix.com/manual/v1.1/web.reports.php
    And other places. It would be great if you could fix it.
    cheers.
    -Simon
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Thanks for pointing to this. Actually v1.1 Manual is not ready yet, so it may have duplicate or missing information. Will be fixed soon!
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • safl
      • May 2005
      • 103
      im looking forward to that
      Btw can you tell me the difference between, zabbix_agent and zabbix_agentd. And maybe guide me to some docs on how to use zabbix as a distributed monitor?
      and for this and thank you very much!
      Great project! I really love that you have documented the SQL-tables so well. Since i'm currently trying to integrate ZAbbix with Ticket system.
      • safl
        • May 2005
        • 103
        Just a note:
        zabbix_agent and zabbix_agentd does the same thing.
        The difference is:
        zabbix_agent i used with inetd and zabbix_agentd is a standalone daemon.
        If this is wrong please correct me.
        • zebulon
          duplicate line on Supported Parameters by Platform
          Hello you have a duplicate line on chapter Supported Parameters by Platform on filesize[*]
          http://www.zabbix.com/manual/v1.1/config_items.php
          sorry for my poor english.
