InnoDB : ibdata growing growing and growing !
  • n0mad44
    • Jan 2008
    I'm using zabbix with mysql 5.0.22 and InnoDB (as recommended). However my ibdata is growing every day (insteed of housekeeper and other regulation processes).
    I read that's due to InnoDB : it's not able to reuse freed space (or something like that )
    For now the only solution I have is to dump my base, stop mysql, erase ibdata and restore the dump.
    Have you any information/trick to make my ibdata smaller ? I don't think I'm the only one with this problem.. how do you do ?
    Thanks,
    n0mad.
  • eli.stair
    • May 2006
    • 20
    Setting InnoDB 'file per table'
    You're looking for 'innodb_file_per_table' in my.cnf. You'll find more detailed info on the mysql site when you search for it.
    Cheers,
    /eli
    • Niels
      • May 2007
      • 239
      You're right that the file wont shrink, and even innodb_file_per_table wont help you with that. I still like to use it to keep the file system more manageable, but that's personal taste.
      The trick you're looking for is what you've already stated: dump and restore.
      You _may_ be able to change some tables from innodb to myisam, but that's a lot of bother with unknown consequences.
      My advice is: Buy large discs, dump and restore if needed.
      • just2blue4u
        • Apr 2006
        • 347
        i had a similar issue.
        Already fount this thread? http://www.zabbix.com/forum/showthread.php?t=8641
        Big ZABBIX is watching you!
        (... and my 48 hosts, 4513 items, 1280 triggers via zabbix v1.6 on CentOS 5.0)
        • pierre-hoffmann
          • Jan 2008
          • 133
          Make an
          mysql zabbix -u root -p
          OPTIMIZE TABLE xxxx
          on each table this defrag tablespace but lock table ...
          Regards,
          Pierre.
          P.Hoffmann
          System & Network Admin.
          __________________________
          Zabbix version 1.8.1
          Hosts monitored 1300
          OS Novell SLES 10 SP2
          • xs-
            • Dec 2007
            • 393
            • just2blue4u
              • Apr 2006
              • 347
              here's what i do:
              [root@server ~]# crontab -l
              # taeglich: MySQL-Backup aller DBs
              0 0 * * * nice mysqldump --flush-logs --delete-master-logs --all-databases -p'geheim' > /root/mysql-db-dump-imv.sql && echo "DB-Backup erstellt"|| echo "FEHLER BEIM ERSTELLEN DES DB-DUMP"
              # Montags morgens: MySQL-DBs optimieren
              0 5 * * 1 /etc/init.d/zabbix_server stop && mysqlcheck -Aoqp'geheim' && /etc/init.d/zabbix_server start || echo "FEHLER BEIM CHECKEN DER MYSQL-DBs"
              [root@server ~]#
              • Jason
                • Nov 2007
                • 431
                Is is possible to run the mysqlcheck -o without it crashing zabbix_server? I really don't want to restart zabbix_server often as it resets all my triggers on stuff such as event logs etc...
                I'd ideally like to run it as a nightly cron script, but can't if it means a zabbix_server restart
