XML Generator for switches
  • skullone
    • Mar 2007
    • 46
    #16
    Originally posted by troffasky
    Fixed issue where ifType was 1 ("other"). Not adding ifType 1 as I'm yet to find a host where ifType 1 ever has any traffic.
    Tested with Cisco 877.
    Doesn't work with SNMPv1 agents.
    Nice addons for a nice scripts.
    I looked at it briefly, and it looks like a good script to make XML templates from any number of SNMP enabled devices or servers for hardware monitoring.
    First thought comes to mind, Dell OpenManage SNMP items, Sun Fire SNMP items, Power distribution units (monitor amperage, voltage, watts, temperature).
    I'll try to come up with some stuff later this week and update!
    • elg
      • Feb 2009
      A very big thx, this templater works really fine for me. I am currently installing all switchs we have (22 but 5 differents brand) and make a unique snmp community. My zabbix server is growing everyday
      • consultorpc
        • Apr 2008
        • 16
        #18
        Thank you ! It works flawlessly.
        • erikklaassen
          • Sep 2007
          • 13
          #19
          Very great tool!
          Some triggers where not working because of the ">" expression. I replaced > with > and that worked fine.
          I also added ifAlias in my port, trigger, graph descriptions.
          • troffasky
            • Jul 2008
            • 639
            #20
            I was wondering what to do with ifAlias vs. ifDescr. I was thinking perhaps use ifDescr by default, but prefer ifAlias if it's there, as ifAlias is usually the user-created description for an interface eg "Fibre link to core switch" vs. "Gi0/1".
            Then again, maybe I should stop wasting time with this perl script and focus on this instead:
            • consultorpc
              • Apr 2008
              • 16
              #21
              Total Bandwidth Calculation for Cisco Switches
              I have been redirected from my Zabbix Cookbook forum thread to this thread. The original post I made is: http://www.zabbix.com/forum/showthre...3896#post43896
              Sorry, if I am doing duplicate posting. I have used the xml file and modified to use with the cisco switch. It is working perfect now. What I would like to do is calculate Total Bandwidth of each interface in daily, weekly and monthly basis.
              I hope I will get a solution from this thread.
              Thanks in advance,
              consultorpc
              • troffasky
                • Jul 2008
                • 639
                #22
                All the script does is generate XML templates for Zabbix. It can't add functionality to Zabbix that isn't already there. Nelsonab's script presumably works by querying the backend DB, which is something that can't done through an XML template.
                • asottomayor
                  • Oct 2009
                  Modules needed to run script
                  Could you tell me what modules do I need to install to run your script ?
                  I use fedora core 8, so can use yum to do it.
                  Thanks in advance,
                  Afonso
                  • asottomayor
                    • Oct 2009
                    Thanks in advance,
                    Afonso
                    • troffasky
                      • Jul 2008
                      • 639
                      #25
                      These are the modules that the script uses:
                      use Time::localtime;
                      use Net::SNMP;
                      use Getopt::Long;
                      How you install those modules depends on what environment you're running the script in.
                      • asottomayor
                        • Oct 2009
                        Configuring for script use
                        Ok, after installing CPAN managed to get modules.
                        But what should i put in "Delay factor for all items" ?
                        What does it means ? And what is the utilization Zabbix makes ?
                        I'm almost there, thanks for your help.
                        Afonso
                        • asottomayor
                          • Oct 2009
                          Errors while importing xml
                          Managed to get the xml file, it was needed "Y" not "y"....
                          But while importing to zabbix it says several errors like :
                          Added trigger 'Port 029 Vlan109 administrative status has changed' to host 'C355012G-02-A1'
                          Added trigger 'Port 029 Vlan109 status has changed' to host 'C355012G-02-A1'
                          Incorrect trigger expression. [ ... ... ]
                          And
                          Added trigger 'Port 011 GigabitEthernet0/11 administrative status has changed' to host 'C355012G-02-A1'
                          Added trigger 'Port 011 GigabitEthernet0/11 status has changed' to host 'C355012G-02-A1'
                          And
                          Added trigger 'Port 012 GigabitEthernet0/12 administrative status has changed' to host 'C355012G-02-A1'
                          Added trigger 'Port 012 GigabitEthernet0/12 status has changed' to host 'C355012G-02-A1'
                          No such monitored parameter (Port 13 Speed) for host (C355012G-02-A1)
                          No such monitored parameter (Port 13 State Admin) for host (C355012G-02-A1)
                          No such monitored parameter (Port 13 State) for host (C355012G-02-A1)
                          I don't have port 13, only 12 on this host.
                          But it works on zabbix, just don't understand why says this errors.
                          Thanks in advance
                          Afonso
