VB script to send specific eventlog entries
  • flexguy
    • Sep 2008
    • 19
    ' VB script to send specific eventlog entries to zabbix server
    ' edit Zabbix Server IP, Hostname and Keyname in commandstring to your needs
    ' create item in zabbix:
    ' Type: ZABBIX trapper
    ' Key: new_event
    ' Type of information: Text
    ' Default Logfiles: Application, Security, System, Internet Explorer
    ' EventTypes: 1 = Error, 2 = Warning, 3 = Information, 4 = Succes audit, 5 = Failure audit
    ' WMI info source: WMITools.exe
    strComputer = "."
    Set objWMIService = GetObject("winmgmts:{(Security)}\\" & _
    strComputer & "\root\cimv2")
    Set colEvents = objWMIService.ExecNotificationQuery _
    ("Select * from __instancecreationevent where " _
    & "TargetInstance isa 'Win32_NTLogEvent' " _
    & "and TargetInstance.Logfile = 'System' " _
    & "and TargetInstance.EventType = '1' ")
    Do
    Set objEvent = colEvents.NextEvent
    SendString = Chr(34) & objEvent.TargetInstance.Logfile & "," & objEvent.TargetInstance.EventType & _
    "," & objEvent.TargetInstance.User & "," & objEvent.TargetInstance.ComputerName & _
    "," & objEvent.TargetInstance.Message & Chr(34)
    set WshShell = CreateObject("wscript.Shell")
    commandstring="c:\zabbix\zabbix_sender.exe -z 192.168.2.199 -s SERVER001 -k new_event -o " & SendString
    WshShell.Run commandstring,0
    Loop
  • cjwallace
    • Sep 2008
    • 126
    Thanks very much for posting this script as this is something i have been trying to get working for some time.
    The Zabbix event log monitoring has not been very reliable for me so this could be a great replacement.
    I can see from
    that this is how you are telling the script with events to look for.
    But what if i want the script to check for the following
    Source = Security
    Type = Success Audit
    Category = Account Management
    Event ID = 633 & 632
    Any ideas or are you just pulling the information in to Zabbix and letting Zabbix filter from there?
    Thanks in advance for any help you may give
    Cheers
    Craig
    • flexguy
      • Sep 2008
      • 19
      adjustments
      Craig,
      You can place the selection criteria in the "event listener" or in the do-loop or in both. I've choosen to keep the do-loop as short as possible, performance-wise.
      No filtering is done after the text has entered Zabbix. One could make a script, that cuts up the event text, based on a trigger and executed through an action. If I find the time, I will post a howto on basic asset tracking (windows only, software&hardware) through Zabbix, which I wrote once. It works with splitting an item (text) and putting it in an extra table I added to the Zabbix database.
      Stay tuned,
