bind9 statistics: statistics-channels
  • Filter
    I recently added a bind9 monitoring way I have not seen before. Starting from 9.5(?) you can create a statistics channel in bind:
    statistics-channels {
    [ inet ( ip_addr | * ) [ port ip_port ] [allow { address_match_list } ]; ]
    [ inet ...; ]
    It creates a http server and outputs nothing but an xml file. For example to get the bind9 memory allocation (channel bound to localhost:8099):
    wget --quiet --output-document=- http://127.0.0.1:8099|grep TotalUse | sed -e 's/<[^>]*>//g')
    Now it is easy to add to the zabbix-agentd.conf and put into the monitoring process.
    I use the "xml2" package to convert the xml format to text, but php or perl experts probably can develop much better solutions.
    The default config for bind is (/etc/bind9/named.conf.local):
    inet 127.0.0.1 port 8053 allow { 127.0.0.1; };
    Zabbix agentd config:
    UserParameter=bind9.queries,/usr/local/bind9getstats/bin/bind9getqueries.sh
    UserParameter=bind9.memuse,/usr/local/bind9getstats/bin/bind9memuse.sh
    The scripts are in a svn repo:
    cd /usr/local && svn co http://svn.fisher.hu/bind9getstats
    The usernameass is guest:guest
    I attached a exported template. I believe all of these workin. At least for me
      bind9memuse.sh Unit
      the script bind9memuse.sh returns in Kbytes the use of memory ?? what is the unit ?
      tanks
        Regarding my experiences it returns the allocated memory in bytes.
          Thanks for the info. I ended up doing this with some custom UserParameters that are similar to that script.
          zabbix_agentd.conf:
          UserParameter=bind.queries.in[*],curl http://localhost:8053/ 2>/dev/null | xml2 | grep -A1 "/isc/bind/statistics/server/queries-in/rdtype/name=$1$" | tail -1 | cut -d= -f2
          UserParameter=bind.queries.out[*],curl http://localhost:8053/ 2>/dev/null | xml2 | grep -A1 "/isc/bind/statistics/views/view/rdtype/name=$1$" | tail -1 | cut -d= -f2
          Then setup item keys like:
          bind.queries.in[A]
          bind.queries.in[PTR]
          bind.queries.out[A]
          etc.
            I'm using bind 9.7.3 and this script "bind9getqueries.sh" constantly returning zero results. Sorry, but I'm dummy with linux systems.
              Stupid! Forgot to install xml2 libraries.
                Old thread, I know....
                I wrote a couple of bash one-liners that don't require xml2
                This one is for per-zone statistics and expects variable 1 = domain and variable 2 = stat type (QrySuccess, QryNXDOMAIN, etc):
                UserParameter=bind.stat[*],curl -s http://localhost:8053 | sed -e '/>$1/,/\/counters/!d' | sed -e 's/ //g' | grep '<$2>' | sed -e 's/.*>\(.*\)<.*/\1/'
                This one is for total query stats per record type and expects variable 1 = stat type (A, AAAA or PTR):
                UserParameter=bind.stat.queriesin[*],curl -s http://localhost:8053 |  sed -e '/<queries-in>/,/<\/queries-in>/!d' | grep -A1 '<name>$1</name>' | tail -1 | sed -e 's/ //g' | sed -e 's/.*>\(.*\)<.*/\1/'
                  Thank you
                  \o/
                    Recently I had to use the following line (bind 9.7):
                    $1: domain
                    $2: qry type like A, PTR, MX, AAAA, etc.
                    UserParameter=bind.stat[*],curl -s http://localhost:8053 | sed -e '/>$1/,/\/resstat/!d' -e '/>$2</,/\/counter/!d' -e 's/<[^>]*>//g' -e '1,1 d'
                      ATM it looks there is no per domain stast available. I keep researching if the stats format is changed or what.
                        I have updated the oneliner:
                        UserParameter=bind.stat[*],curl -s http://localhost:8053 | sed -e '/>$1/,/\/counters/!d' -e /$2/\!d -e 's/.*>\([0-9]*\)<.*/\1/g'
                        It is one sed no grep or else.
                        Announcement
                        No announcement yet.
