I'll be looking for that!!!
Apache monitoring with Zabbix
Check your "Allow from" apache config file:
Code:<Location /server-status> SetHandler server-status Allow from 127.0.0.1 # If using a remote host for monitoring replace 127.0.0.1 with its IP. Order deny,allow Deny from all </Location> ExtendedStatus On # Optional. Must be in global scope and not in a virtual host978 Hosts / 16.901 Items / 8.703 Triggers / 44 usr / 90,59 nvps / v1.8.15Comment
I already enable apache on host that i want to monitor. i can call the process from browser or from terminal in my server but it not appear in zabbix monitoring. I change the syntax to call apache process because the syntax before, agent cannot support. When i change, agent support but the value show zero. Do you know how to solve this?Check your "Allow from" apache config file:
Sue, can you be more clear about what you wanted, do you want to monitor other than localhost with this script? If so, you can't do that, localhost is hardcoded and you have to change it to remote host but it is easier if you put this script to remote host.
But I have modified script also to be used as external check script. So that you can use this on the zabbix server without putting on remote host. I am assuming that you already know how to use external scripting function?
Bashman if you accept it here is the version 1.3 also can be used as external check
Attached FilesComment
That's great!, the wiki is updated with your new script:Hi,
http://www.zabbix.com/wiki/templates/apache#method_3
Thanks again Murat!978 Hosts / 16.901 Items / 8.703 Triggers / 44 usr / 90,59 nvps / v1.8.15Comment
Unfortunately i think i dont know. i try to add this line in zabbix scriptHi,
and put this line in zabbix_agentd.conf/usr/local/zabbix/zapache {HOST.CONN}
After restart the agent, i still cannot monitor remote host. Can you explain??UserParameter=apache[*],/usr/local/zabbix/zapache \$2
OK..i success to monitor the item. But i want to know, is it the value i get is right? for example, read request. why my read request value always 0? even when i try many times to request that page is always 0. the changes only in sending reply. Maybe i not understand how it works. can anybody explain to me?Comment
sue, the scoreboard reflects what the various workers are doing, at the time of the check.
Reading the request is a very short operation, resulting in the usual longer operation of sending the reply.
If the server is not very busy you are less likely to catch the reading of requests.
You could consider running the checks more often to increase the resolution of the graphs.
Depending on how you configured it you can check the scoreboard via your web browser (e.g.: http://192.168.1.10/server-status) to verify if the values zabbix get look correct.Comment
Apache Monitoring Script - Method 3 + templates
Thanks! With the zapache version 1.3, the method 3 rocks!
By the way, here's the apache template for those who need itAttached FilesComment
This is great!!!!
Thanks archang3llo, your template is in the wiki:
http://www.zabbix.com/wiki/templates/apache#method_3978 Hosts / 16.901 Items / 8.703 Triggers / 44 usr / 90,59 nvps / v1.8.15Comment
Hi
I am experiencing problem with the Method 1 described in Wiki.
The script is getting the scientific values for the CPU load when the system is idle and CPULoad parameter becoming not supported:
tmp0Vn915:host001 apache[localhost,CPULoad] 9.16204e-5
7892:20121227:112001.782 item [host001:apache[localhost,CPULoad]] became not supported: Received value [9.16204e-5] is not suitable for value type [Numeric (float)]
I am tried to find the part in the script where the values are collected but as I am not so strong in python it is a little bit tricky for me
Just wondering if someone else noticed this?
Regards,
AregComment
Hi
Just added the following lines to the original fetch.py file which solved my issue. Testing now but seems it is Ok.
Regards,Code:230c230,233 < tempfile.write("%s apache[%s,%s] %s\n" % (opts.zabbixsource, opts.host, key, val)) --- > if key == 'CPULoad': > tempfile.write("%s apache[%s,%s] %1.9f\n" % (opts.zabbixsource, opts.host, key, float(val))) > else: > tempfile.write("%s apache[%s,%s] %s\n" % (opts.zabbixsource, opts.host, key, val))
AregComment
Hi
Does anyone have any instructions on how to implement Method 3 on this URL https://www.zabbix.com/wiki/doku.php...pache#method_3 please?
I'm a newbie and am not sure where to put the bash script and how it should be executed (via cron or called from zabbix somehow?).
Sorry to be thick and thanks very much to anybody who can spare me the time to explain. I really need this to work as I'm having lots of Apache related issues and need to get some insight into what our app is doing with Apache.
Kind regards
BrynComment
