Problem With Type Of Check
Try using mass-update to change the type of check from "Zabbix Agent (Active)" to "Zabbix Trapper". I --think-- that will fix the problem you're having. In either case I'll be updating the XML Import with the right check type in the next couple days.
-Paul
-Paul
