Monitoring ESX datastore
  • jay
    • Dec 2009
    • 11
    Here is a small script to monitor ESX datastore. It is very simple so be free to improve it :
    ZABBIX_SERVER="zabbixhostname";
    ZABBIX_PORT="zabbixport";
    ZABBIX_SENDER="/pathtozabbixsender";
    KEY=$1;
    HOST="ESXhostname"
    TOTAL=100
    VALUE=""
    VALUE=`/usr/sbin/vdf -h | grep /vmfs/volumes/$1 | awk '{print $4}' | sed 's/%//g'`
    if [[ $VALUE = [0-9][0-9] ]] || [[ $VALUE = [0-9] ]]; then
    VALUE=$(( $TOTAL -$VALUE ))
    $ZABBIX_SENDER -z $ZABBIX_SERVER -p $ZABBIX_PORT -s $HOST -k $KEY -o $VALUE
    else
    $ZABBIX_SENDER -z $ZABBIX_SERVER -p $ZABBIX_PORT -s $HOST -k $KEY -o "0"
    fi
    Regards
    Jay
  • benito103e
    • Jun 2010
    • 24
    details
    Thanks for the script, i'm a beginner in zabbix monitoring and i'm french So please excuse me if i make mistakes.
    I would want to know how you use this script?
    What is the language ? is it just algo ?
    I'm searching the best way to monitoring my ESX 4:
    - Zabbix agent
    - snmp (with Vsphere?)
    Thanks you.
    • Murilex
      • Nov 2009
      • 124
      It's a little bit difficult to have all configured, but I use and recommend the usage of the scripts presented on this post:
      My hardware is not HP and I could easily adapt the scripts in order to get them working.
      • benito103e
        • Jun 2010
        • 24
        Originally posted by Murilex
        ...but I use and recommend the usage of the scripts presented on this post:
        Ok But how do you use these scripts?
        I've Dells
        - Did you install zabbix agent on the esx (I have the impression that is what dima_dm did?? )
        Excuse me, I find it not easy to understand all the procedure because of my tongue
        Thanks for your help
        • Murilex
          • Nov 2009
          • 124
          Although the scripts were made for ESX machines, I successfully use them to monitor ESXi (freeware version of VMware ESX) servers.
          To use the scripts, you first have to elect a machine that will collect the ESX data. One option is to use zabbix server. As those scripts use to degread a little bit the server performance, I've decided to use another machine to collect the ESX data and send them to zabbix server.
          On this elected machine I've installed "VMware Infrastructure (VI) Perl Toolkit" and "WBEM wbemcli" as required on the post http://www.zabbix.com/forum/showthread.php?t=15691. Then I've configured cron to run "/etc/zabbix/zabbix_wbem_vmware.pl" and "/etc/zabbix/zabbix_perl_api_vmware.pl" regularly and send the output to zabbix server. On the zabbix server I've created a script that reads this output.
          • benito103e
            • Jun 2010
            • 24
            Very Interesting
            Is there a software required in ESX (to add ?) ?
            does Your script use the zabbix_sender??
            I think I will use Zabbix_server to collect ESX data, and change a little bit the script to send directly information to zabbix and not write it on a file (perhaps the two things at the same time)
            --> zabbix server will launch the script : deleting cron
            Thanks !
            • Murilex
              • Nov 2009
              • 124
              No, it's not necessary to install any software in ESX. I don't use zabbix_sender presently, but this is for sure a good alternative.
              • benito103e
                • Jun 2010
                • 24
                Ok,
                So what do you use to get data in Zabbix ?
                I will read the manuel to how use script, and get back information in zabbix server !
                Thank you very much !
                • Murilex
                  • Nov 2009
                  • 124
                  Hello benito103e. As I said, I use a simple script on zabbix server that read data from a plain file. This plain file is generated on a helper machine (that I elected) and moved to zabbix server from times to times (by using scp!).
                  • benito103e
                    • Jun 2010
                    • 24
                    Hi Murilex,
                    Thanks for all your precision, It lights me
                    I'll choose my way to get data, with your advice.
                    • gavind
                      • Mar 2013
                      • 59
                      Originally posted by benito103e
                      Hi Murilex,
                      Hi buddy, were you able to set this up for production already? How is it?
                      • Voxie
                        • Jul 2009
                        • 24
                        We have created a Windows powershell script:
                        Title: 			Report-Datastores.ps1
                        Description: 	Report Datastore usage for all Datastores managed by vCenter
                        Requirements: 	Windows Powershell and the VI Toolkit
                        Usage:			.\Report-Datastores.ps1
                        #ADD VMWARE PSSNAPIN
                        Add-PSSnapin -Name “VMware.VimAutomation.Core”
                        #FORCE TO LOAD VMWARE POWERSHELL PLUGIN
                        [Reflection.Assembly]::LoadWithPartialName(“vmware.vim”)
                        #Global Functions
                        #This function generates a nice HTML output that uses CSS for style formatting.
                        function Generate-Report {
                        				Foreach ($store in $report){
                        					echo $($store.name)
                        					cmd.exe /c "C:\Zabbix\zabbix_sender.exe -z <zabbixip> -s $($store.name) -k data.store.total.space -o $($store.CapacityMB)"
                        					cmd.exe /c "C:\Zabbix\zabbix_sender.exe -z <zabbixip> -s $($store.name) -k data.store.free.space -o $($store.FreeMB)"
                        					cmd.exe /c "C:\Zabbix\zabbix_sender.exe -z <zabbixip> -s $($store.name) -k data.store.free.percent -o $($store.PercFRee)"
                        #Login details
                        $username = '<username>'
                        $password = '<password>'
                        #Current, Previous, Difference File information
                        $digits = 2
                        $Folder = 'C:\Reports'
                        #List of servers including Virtual Center Server.  The account this script will run as will need at least Read-Only access to Virtual Center
                        $VIServer = "<vcenter server"
                        #Initialise Array
                        $Report = @()
                        # Connect to Virtual Center
                        $VC = Connect-VIServer $VIServer -user $username -password $password
                        # Get all datastores and put them in alphabetical order
                        #$datastores = Get-Datastore | Sort-Object Name
                        #Get all datastores and put them in alphabetical order
                        		foreach ($server in $serverlist){
                        		# Check is server is a Virtual Center Server and connect with current user
                        		if ($server -eq "VCServer"){Connect-VIServer $VIServer}
                        		# Use specific login details for the rest of servers in $serverlist
                        		else {Connect-VIServer $VIServer -user $username -password $password}
                        		Get-Datastore | Sort-Object Name | %{
                        			$Store = {} | Select Name, CapacityMB, FreeMB, PercFree
                        			$Store.Name = $_.name
                        			$Store.CapacityMB = [math]::Round(($_.capacityMB*1024)*1024,0)
                        			$Store.FreeMB = [math]::Round(($_.FreeSpaceMB*1024)*1024,0)
                        			$Store.PercFree = [math]::Round(100*$_.FreeSpaceMB/$_.CapacityMB,$digits)
                        			$Report += $Store
                        		# Disconnect from Virtual Center
                        		Disconnect-VIServer -Confirm:$False
                        # Generate the report and email it as a HTML body of an email
                        Generate-Report
                        You only have to change:
                        <zabbixip> = IP of the zabbix server
                        <username> = Username for vCenter
                        <password> = Password for vCenter
                        We run the script on a Windows server with the vSphere client and commandline tools installed.
                        In zabbix we have created a template:
                        <?xml version="1.0" encoding="UTF-8"?>
                        <zabbix_export version="1.0" date="17.07.13" time="14.30">
                          <hosts>
                            <host name="Databalance - VMWare datastores">
                              <proxy_hostid>0</proxy_hostid>
                              <useip>1</useip>
                              <dns></dns>
                              <ip>127.0.0.1</ip>
                              <port>10050</port>
                              <status>3</status>
                              <useipmi>0</useipmi>
                              <ipmi_ip>127.0.0.1</ipmi_ip>
                              <ipmi_port>623</ipmi_port>
                              <ipmi_authtype>0</ipmi_authtype>
                              <ipmi_privilege>2</ipmi_privilege>
                              <ipmi_username></ipmi_username>
                              <ipmi_password></ipmi_password>
                              <groups>
                                <group>Templates</group>
                              </groups>
                              <triggers>
                                <trigger>
                                  <description>Low space on datastore</description>
                                  <type>0</type>
                                  <expression>{Databalance - VMWare datastores:data.store.free.space.last(0)}&lt;53687091200</expression>
                                  <url></url>
                                  <status>0</status>
                                  <priority>4</priority>
                                  <comments></comments>
                                </trigger>
                                <trigger>
                                  <type>0</type>
                                  <expression>{Databalance - VMWare datastores:data.store.free.space.last(0)}&lt;70530636800 &amp; {Databalance - VMWare datastores:data.store.free.space.last(0)}&gt;53687091200</expression>
                                  <url></url>
                                  <status>0</status>
                                  <priority>2</priority>
                                </trigger>
                              </triggers>
                              <items>
                                <item type="2" key="data.store.free.percent" value_type="0">
                                  <description>Free Percent Datastore</description>
                                  <ipmi_sensor></ipmi_sensor>
                                  <delay>60</delay>
                                  <history>90</history>
                                  <trends>365</trends>
                                  <status>0</status>
                                  <data_type>0</data_type>
                                  <units>%</units>
                                  <multiplier>0</multiplier>
                                  <delta>0</delta>
                                  <formula>0</formula>
                                  <lastlogsize>0</lastlogsize>
                                  <logtimefmt></logtimefmt>
                                  <delay_flex></delay_flex>
                                  <authtype>0</authtype>
                                  <username></username>
                                  <password></password>
                                  <publickey></publickey>
                                  <privatekey></privatekey>
                                  <params></params>
                                  <trapper_hosts></trapper_hosts>
                                  <snmp_community></snmp_community>
                                  <snmp_oid></snmp_oid>
                                  <snmp_port>161</snmp_port>
                                  <snmpv3_securityname></snmpv3_securityname>
                                  <snmpv3_securitylevel>0</snmpv3_securitylevel>
                                  <snmpv3_authpassphrase></snmpv3_authpassphrase>
                                  <snmpv3_privpassphrase></snmpv3_privpassphrase>
                                  <valuemapid>0</valuemapid>
                                  <applications>
                                    <application>VMWare Datastores</application>
                                  </applications>
                                </item>
                                <item type="2" key="data.store.free.space" value_type="3">
                                  <description>Free Space Datastore</description>
                                  <delay>60</delay>
                                  <status>0</status>
                                  <units>B</units>
                                  <delta>0</delta>
                                  <params></params>
                                  <applications>
                                  </applications>
                                </item>
                                <item type="2" key="data.store.total.space" value_type="3">
                                  <description>Total Space Datastore</description>
                                  <delay>60</delay>
                                  <status>0</status>
                                  <units>B</units>
                                  <delta>0</delta>
                                  <params></params>
                                  <applications>
                                  </applications>
                                </item>
                              </items>
                              <templates/>
                              <graphs>
                                <graph name="Datastore space" width="900" height="200">
                                  <ymin_type>0</ymin_type>
                                  <ymax_type>0</ymax_type>
                                  <ymin_item_key></ymin_item_key>
                                  <ymax_item_key></ymax_item_key>
                                  <show_work_period>0</show_work_period>
                                  <show_triggers>0</show_triggers>
                                  <graphtype>0</graphtype>
                                  <yaxismin>0.0000</yaxismin>
                                  <yaxismax>100.0000</yaxismax>
                                  <show_legend>0</show_legend>
                                  <show_3d>0</show_3d>
                                  <percent_left>0.0000</percent_left>
                                  <percent_right>0.0000</percent_right>
                                  <graph_elements>
                                    <graph_element item="Databalance - VMWare datastores:data.store.total.space">
                                      <drawtype>2</drawtype>
                                      <sortorder>0</sortorder>
                                      <color>000000</color>
                                      <yaxisside>0</yaxisside>
                                      <calc_fnc>2</calc_fnc>
                                      <type>0</type>
                                      <periods_cnt>5</periods_cnt>
                                    </graph_element>
                                    <graph_element item="Databalance - VMWare datastores:data.store.free.space">
                                      <drawtype>1</drawtype>
                                      <sortorder>1</sortorder>
                                      <color>009900</color>
                                      <type>0</type>
                                    </graph_element>
                                  </graph_elements>
                                </graph>
                              </graphs>
                              <macros/>
                            </host>
                          </hosts>
                          <dependencies/>
                        </zabbix_export>
                        With schedule tasks we run the script every 30 minutes.
                        It generates a trigger when datastore is almost full.
                        Hopefully somebody can use the script.
                        • hemaworst
                          • Mar 2014
                          I've tried this script but run into this error message:
                          ESXVOL1
                          the system can not find the file specified
                          ESXVOL2
                          etc.
                          Maybe you can help?
                          p.s. sorry for my engelish
