Current Disk Queue Length
  • bobrivers
    • Feb 2007
    • 115
    In my windows servers, I'm monitoring a counter called "current disk queue length". Basically, accordingly with MS: "Current Disk Queue Length is the number of requests outstanding on the disk at the time the performance data is collected."
    I like it because it's simple.
    My question is, does linux has something like this counter?
    I was looking into IOSTAT, but none of the counters provided seems to be equal to current disk queue lenght. The most similar is "avgqu-sz", but it's an average and the windows one is the actual value measured when the zabbix agent was contacted.
    TIA,
    Bob
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Please could you register a feature request? Meanwhile you can create a simple user parameter, which would parse output of /proc or vmstat.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • troffasky
      • Jul 2008
      • 639
      A generic way of accessing data in /proc (like perf[] does on Windows agents) would be useful. Especially if Zabbix would query the agent for what's in /proc, instead of having to ssh to the host to check first then add it.
