Ok,
How many java processes there are? I mean there are other java application running?
There is a firewall installed? ( May be that the object that send response to Zabbix have problem if packet are dropped)
Are you sure that is Orabbix java process that consume all your cpu? i mean have you verified with a Top? (because may be that It's not directly Orabbix that use all that CPU but it's just the cause)
It's hard to debug because on log there aren't error at all. I see that Orabix retrieve all the needed information and sleep for 5 minute, and run so again. I've see that there are some problem to connection on RDBMS may be that there is a firewall between Orabbix and Oracle?
