You need create an host for each database specified on config.props in parameter DatabaseList with the same name of databases configured on.
After this you apply the template on your host.
Now you should apply this template to your host
If you have configured orabbix daemon and is running the daemon is already sending data to your zabbix server , and you should see the collected data try on latest data if zabbix server is receiving data.
racle:thin:@czab11db.incert.REDACTED.com:1560:CZAB 11DB
when i have time i'll write the code to do that.... it's not so simple...in this way you can have how much as you want querylist
