Orabbix:"Another way to monitor Oracle reloaded"
  • sybex
    • Aug 2008
    • 29
    #31
    Hi, ...
    i changed the config and removed the "dot" ... btw in my inhouse it is working with the dot.
    But now i got another error message:
    PHP Code:
    [root@afcarc01p ~]# tail -f /opt/orabbix/log/orabbix.log
    2010-04-26 11:21:47,820 [mainDEBUG Orabbix Starting configurator...
    2010-04-26 11:21:47,820 [mainDEBUG Orabbix getConnection for database afcrep01P
     2010
    -04-26 11:21:48,461 [mainERROR Orabbix Error on Configurator for database afcrep01P -->Io exceptionGot minus
    one from a read call
     2010
    -04-26 11:21:48,461 [mainERROR Orabbix This Database afcrep01P will be removed
     2010
    -04-26 11:21:48,466 [mainWARN  Orabbix - New Database Foundedadding database afcrep01P
     2010
    -04-26 11:21:48,466 [mainDEBUG Orabbix getConnection for database afcrep01P
     2010
    -04-26 11:21:48,488 [mainERROR Orabbix Error on Configurator for database afcrep01P -->Io exceptionGot minus
     2010
    -04-26 11:21:48,488 [mainERROR Orabbix This Database afcrep01P will be removed
     2010
    -04-26 11:21:48,489 [mainDEBUG Orabbix going in bed...and sleep for 300000 ms
    • dalle
      • Mar 2009
      • 402
      #32
      Originally posted by sybex
      Hi, ...
      PHP Code:
       2010
       2010
       2010
       2010
       2010
       2010
       2010
      seem that something on configuration is wrong, address name, port or something....
      i've tryed and works also with "dot" in front of name.... which version of oracle are you using?
      i've inluded ojdbc14.jar on my distribution of oracle 10g shouldn'te be this but just in case...
      Andrea Dalle Vacche
      website:http://www.smartmarmot.com/
      e-mail:
      Author of:Mastering Zabbix Book - second edition
      Zabbix Network Monitoring Essentials
      • sybex
        • Aug 2008
        • 29
        #33
        Hi, ...
        we are using:
        Oracle Database 10g Enterprise Edition Release 10.2.0.4.0 - 64bit Production
        I will now install the latest java version. Before it was 1.6 update 9.
        • dalle
          • Mar 2009
          • 402
          #34
          Hi, ...
          we are using:
          we are using oracle 10g Enterprise 10.2.0.4 64bit Production Release on windows 2003r2 so it's the same.
          I monitor with this daemon 43 production instances and 22 test/develop instances without trouble, i'm sorry for those problem, i'm looking inside the code to help you.. if i find something i'll notice.
          My Zabbix server is RedHat EL5.4 with java-1.6.0-openjdk-1.6.0.0-1.7.b09.el5
          Andrea Dalle Vacche
          e-mail:
          • sybex
            • Aug 2008
            • 29
            #35
            Hi, ...
            after installing the latest java JRE 1.6.20 i got one of my two databases running.
            But the original one i'd tried before have still the same problem. So Orabbix works fine.
            Our DBA is now analyzing the situation and comparing the databases.
            thx for your great work
            • dalle
              • Mar 2009
              • 402
              #36
              Hi, ...
              FINALLY!!!! I'm so happy to hear this nice day! i wasn't able to find the problem.
              Thankyou for your feedback!
              Andrea Dalle Vacche
              e-mail:
              • dalle
                • Mar 2009
                • 402
                #37
                new blog
                Hi to every one i've moved my blog here
                nice day
                Andrea Dalle Vacche
                e-mail:
                • nayara
                  • Mar 2010
                  • 43
                  #38
                  Help
                  Hello
                  Sorry for Google translate English.
                  I am trying to configure orabbix, but it returns the error message below.
                  Note: the level of logging is as DEBBUG
                  2010-05-06 17:38:44,269 [main] INFO  Orabbix - Starting Orabbix Version 0.6
                   2010-05-06 17:38:44,276 [main] DEBUG Orabbix - Starting configurator...
                   2010-05-06 17:38:44,276 [main] DEBUG Orabbix - getConnection for database XXXX
                   2010-05-06 17:38:45,304 [main] INFO  Orabbix - Connected as ZABBIX
                   2010-05-06 17:38:45,315 [main] INFO  Orabbix - --------- on Database -> XXXX
                   2010-05-06 17:38:45,318 [main] DEBUG Orabbix - retrieve connection for dbname ->XXXX
                   2010-05-06 17:38:45,335 [main] DEBUG Orabbix - sharedpooldatasource idle connection -->0 active connetion -->1 dbname -->XXXX
                   2010-05-06 17:38:45,335 [main] DEBUG Orabbix - Starting ZabbixTrapper for XXXX
                   2010-05-06 17:38:45,343 [main] DEBUG Orabbix - going in bed...and sleep for 300000 ms
                   2010-05-06 17:38:45,344 [pool-1-thread-1] DEBUG Orabbix - Starting dbJob on database XXXX
                   2010-05-06 17:38:45,344 [pool-1-thread-1] DEBUG Orabbix - Actual query is archive statement is select round(A.LOGS*B.AVG/1024/1024/10) from ( SELECT COUNT (*)  LOGS FROM V$LOG_HISTORY WHERE FIRST_TIME >= (sysdate -10/60/24)) A, ( SELECT Avg(BYTES) AVG,  Count(1), Max(BYTES) Max_Bytes, Min(BYTES) Min_Bytes  FROM  v$log) B
                   2010-05-06 17:38:45,376 [pool-1-thread-1] DEBUG Orabbix - resultset returned from query archive resultset -->0
                   2010-05-06 17:38:45,376 [pool-1-thread-1] DEBUG Orabbix - Actual query is audit statement is select username "username", to_char(timestamp,'DD-MON-YYYY HH24:MI:SS') "time_stamp", action_name "statement", os_username "os_username", userhost "userhost", returncode||decode(returncode,'1004','-Wrong Connection','1005','-NULL Password','1017','-Wrong Password','1045','-Insufficient Priviledge','0','-Login Accepted','--') "returncode" from sys.dba_audit_session where (sysdate - timestamp)*24 < 1 and returncode <> 0 order by timestamp
                  My config.props
                  ZabbixServer.Address=X.X.X.X
                  ZabbixServer.Port=10050
                  #frequency of item's refresh
                  OrabbixDaemon.Sleep=300
                  #MaxThreadNumber should be >= than the number of your databases
                  OrabbixDaemon.MaxThreadNumber=100
                  #put here your databases in a comma separated list
                  DatabaseList=XXXX
                  #Configuration of Connection pool
                  #Maximum number of active connection inside pool
                  DatabaseList.MaxActive=10
                  #The maximum number of milliseconds that the pool will wait
                  #(when there are no available connections) for a connection to be returned
                  #before throwing an exception, or <= 0 to wait indefinitely.
                  DatabaseList.MaxWait=100
                  DatabaseList.MaxIdle=1
                  #define here your connection string for each database
                  XXXX.Url=jdbc:oracle:thin:@myserver:1521:XXXX
                  XXXX.User=zabbix
                  XXXX.Password=zzzz
                  #DB2.Url=jdbc:oracle:thin:@server2.domain.example.com:<LISTENER_PORT>:DB2
                  #DB2.User=zabbix
                  #DB2.Password=zabbix_password
                  #DB3.Url=jdbc:oracle:thin:@server3.domain.example.com:<LISTENER_PORT>:DB3
                  #DB3.User=zabbix
                  #DB3.Password=zabbix_password
                  #Query Parameter Files
                  OracleQueryListFile=/opt/orabbix/conf/query.props
                  vlw
                  • dalle
                    • Mar 2009
                    • 402
                    #39
                    please be patience, i don't see the error message, can you help me to find your error?
                    Andrea Dalle Vacche
                    e-mail:
                    • nayara
                      • Mar 2010
                      • 43
                      #40
                      It turns out that the script connects to the database, executes the command, but only appears in zabbix information free memory, processor load, processor load5, processor load15 and total memory.
                      I found these entries in the logs.
                      07-MAY-10 03:40:0412154ErrorError 12154 received                                                              logging on to the standby07-MAY-10 03:45:0412154ErrorPING[ARC5]: Heartbeat fail                                                             ed to connect to standby 'xxxxstb'. Error is 12154.07-MAY-10 03:45:0412154Error                                                             Error 12154 received logging on to the standby07-MAY-10 03:50:0412154ErrorPING[A                                                             RC5]: Heartbeat failed to connect to standby 'xxxxstb'. Error is 12154.07-MAY-1                                                             0 03:50:0412154ErrorError 12154 received logging on to the standby07-MAY-10 03:5                                                             5:04
                      Thanks for the quick response
                      • untergeek
                        • Jun 2009
                        • 512
                        #41
                        Hmmm. I wonder if you have this set right:
                        XXXX.Url=jdbcracle:thin:@myserver:1521:XXXX
                        XXXX.User=zabbix
                        XXXX.Password=zzzz
                        The XXXX.Url part, are the Xs the same, exact host name as the host that is receiving memory, load and such? Is it the same as the SID (the 1521:XXXX)?
                        If the hostname currently receiving memory and load information matches the first XXXX, then there is still a problem. If that hostname is the same as the SID, i.e. zabbix hostname, the first and second Xs match, then you're fine. Otherwise, Orabbix is trying to send data to a "host" that isn't defined in Zabbix.
                        For us, we're having separate Zabbix "hosts" that are simply the SID (since we have many databases) which are separate from the CPU and other stuff (also since we have multiple DB instances on the same physical server).
                        Last edited by untergeek; 07-05-2010, 15:57. Reason: Edited for clarity in explanation.
                        • nayara
                          • Mar 2010
                          • 43
                          #42
                          Sorry about the delay in responding.
                          Today I found the following line in the log. Connection refused This appears to many items.
                          2010-05-10 10:23:18,989 [Zabbix-sender] WARN  Orabbix - Warning while sending item dgerror  on host XXXX retry number 10 error:java.net.ConnectException: Connection refused
                          The strange thing is that the connection orabbix can do in SQL db and be able to collect the information.
                          Via SQLPlus connection is established normally.
                          [root@zabbix ~]# sqlplus zabbix/zzzz@XXXX
                          SQL*Plus: Release 11.2.0.1.0 Production on Mon May 10 11:35:36 2010
                          Copyright (c) 1982, 2009, Oracle.  All rights reserved.
                          Connected to:
                          With the Partitioning, OLAP, Data Mining and Real Application Testing options
                          SQL>
                          My tnsname.ora
                          XXXX =
                          (DESCRIPTION =
                          (ADDRESS = (PROTOCOL = TCP) (HOST = myserver) (PORT = 1521))
                          (CONNECT_DATA = (SERVER = shared) (SERVICE_NAME = xxxx))
                          PS: My version of zabbix is 1.8.1.
                          • dalle
                            • Mar 2009
                            • 402
                            #43
                            this seems more that Orabbix is unable to contact the zabbix server to send the collected items.
                            Orabbix normally try 10 times to send the collected items to the server, if server don't respond or is anavailable write this message.
                            Please try do a telnet to your zabbix server configured on your configuration files on definesd port
                            e.g.
                            ZabbixServer.Address=192.168.1.1
                            you should be able to do
                            telnet 192.168.1.1 10050
                            if you receive a connection refused probably or there is a wrong address, or port or there is a firewall that don't allow connection.
                            NOTE: the address and the port specified are of zabbix server and not of agent.
                            Let me know if "telnet 192.168.1.1 10050" work
                            Nice evening (here at least)
                            Dalle
                            Andrea Dalle Vacche
                            e-mail:
                            • sybex
                              • Aug 2008
                              • 29
                              #44
                              Originally posted by nayara
                              Hello
                              My config.props
                              ZabbixServer.Port=[COLOR="red"][B]10050[/B][/COLOR]
                              vlw
                              Hi, ...
                              as far as i know the zabbix server port is not 10050, it is 10051.
                              give a try ... but this error matches also with the "Connection refused" error from the zabbix-sender.
                              • dalle
                                • Mar 2009
                                • 402
                                #45
                                Hi, ...
                                yep true... i'm wrong sorry
                                Andrea Dalle Vacche
                                e-mail:
