MySQLBix to monitor MySQL
  • dalle
    • Mar 2009
    • 402
    I’ve wrote MySQLBix as a fork of Orabbix
    this mean that MySQLBix has the same features of Orabbix:
    • Connection Pooling
    • Multithread
    • No limits on number of monitored databases
    • Is opensource and released under GPL
    and all the other features that every Orabbix user know
    It’s just a pre-release so be patience with him (and me of course )
    Any help to develope this project is really welcome i mean that if someone has some request, want add a query, trigger, item please notice to me.
    all is available as usual on sourceforge or
    here
    Andrea Dalle Vacche
    website:http://www.smartmarmot.com/
    e-mail:
    Author of:Mastering Zabbix Book - second edition
    Zabbix Network Monitoring Essentials
  • sue
    • Mar 2011
    • 41
    i try to use mysqlbix and follow the instruction but still cannot show the latest data. why this happen?
    • dalle
      • Mar 2009
      • 402
      try to see in tail -f /opt/mysqlbix/logs/mysqlbix.log
      what is happening and let me know
      Andrea Dalle Vacche
      e-mail:
      • sue
        • Mar 2011
        • 41
        when i run this command, it give me
        tail: cannot open `/opt/mysqlbix/logs/mysqlbix.log' for reading: No such file or directory
        tail: no files remaining
        • sue
          • Mar 2011
          • 41
          I successfully run mysqlbix but then show this error
          [root@localhost conf]# java.lang.IllegalArgumentException
          at java.util.concurrent.ThreadPoolExecutor.<init>(Thr eadPoolExecutor.java:1275)
          at java.util.concurrent.ThreadPoolExecutor.<init>(Thr eadPoolExecutor.java:1163)
          at java.util.concurrent.Executors.newFixedThreadPool( Executors.java:89)
          at main.main(main.java:105)
          how to solve this problem??
          • dalle
            • Mar 2009
            • 402
            do you have installed java?on my redhat there is
            java-1.6.0-openjdk-1.6.0.0-1.18.b17.el5
            and is tested on ubuntu/redhat/and aix (with oracle jvm)
            try to do the following command
            rpm -qa |grep java
            and doesn't matter where is the database you need to create an user with a password and mysql should listen on some port this software don't work on socket
            let me know
            Andrea Dalle Vacche
            e-mail:
            • dalle
              • Mar 2009
              • 402
              if there are no files may be that is not running or your log4j is configured to log in another place or you have unpacked in a different location (different from the one specified on installation instruction)
              Andrea Dalle Vacche
              e-mail:
              • sue
                • Mar 2011
                • 41
                this error i get from mysqlbix.log
                2011-04-14 15:05:36,873 [main] INFO Mysqlbix - Starting Mysqlbix Version 1.1.0 BETA
                2011-04-14 15:05:36,877 [main] ERROR Mysqlbix - Error on Configurator while retriving query file QueryListFile C:/Dropbox/My Dropbox/workspace/orabbix/conf/query.props (No such file or directory)
                2011-04-14 15:05:36,890 [main] INFO Mysqlbix - Mysqlbix started with pid:17867
                2011-04-14 15:05:36,891 [main] INFO Mysqlbix - PidFile -> ./logs/mysqlbix.pid
                • sue
                  • Mar 2011
                  • 41
                  rpm -qa |grep java
                  let me know
                  [root@localhost ~]# rpm -qa | grep java
                  java-1.6.0-openjdk-1.6.0.0-1.2.b09.el5
                  java-1.4.2-gcj-compat-1.4.2.0-40jpp.115
                  (with oracle jvm)..do i need install oracle jvm??what the function..sory if my question like stupid. i very new with all this and still in learning process. what i know, oracle something like databse. same as mysql. so do we need oracle jvm when want to monitor mysql??
                  i use centos for my os
                  • dalle
                    • Mar 2009
                    • 402
                    where have you downloaded this software? because seems that has a different config file from the one that i've released on my website....
                    please replace in config.props the key QueryListFile with thisone
                    #Query Parameter Files
                    QueryListFile=./conf/query.props
                    Andrea Dalle Vacche
                    e-mail:
                    • dalle
                      • Mar 2009
                      • 402
                      don't worry
                      it's just because Oracle has bought Sun and now Java is a trade mark of Oracle anyway don't worry about your question if you have centos should be something like this
                      yum install java-1.6.0-openjdk
                      try and let me know your progress
                      Andrea Dalle Vacche
                      e-mail:
                      • sue
                        • Mar 2011
                        • 41
                        i take from smartmarmot.com..still got this error after a few second run mysqlbix
                        and at mysqlbix.log
                        2011-04-14 15:45:03,910 [main] INFO Mysqlbix - Starting Mysqlbix Version 1.1.0 BETA
                        2011-04-14 15:45:03,923 [main] INFO Mysqlbix - Mysqlbix started with pid:20169
                        2011-04-14 15:45:03,923 [main] INFO Mysqlbix - PidFile -> ./logs/mysqlbix.pid
                        2011-04-14 15:50:04,237 [main] ERROR Mysqlbix - Error on Configurator for database zabbix -->Communications link failure
                        The last packet sent successfully to the server was 0 milliseconds ago. The driver has not received any packets from the server.
                        2011-04-14 15:50:04,237 [main] INFO Mysqlbix - This Database zabbix removed
                        2011-04-14 15:50:04,237 [main] ERROR Mysqlbix - ERROR on main - Connections is empty or null
                        2011-04-14 15:50:04,239 [main] ERROR Mysqlbix - Error on Configurator while retriving the MysqlbixDaemon.MaxThreadNumber java.lang.NumberFormatException: null
                        • dalle
                          • Mar 2009
                          • 402
                          and at mysqlbix.log
                          do you have specified an account with right username and password and an IP and a port on config.props?
                          Mysql is listening on some port or is runnin with socket?
                          socket are not supported by mysqlbix
                          Andrea Dalle Vacche
                          e-mail:
                          • sue
                            • Mar 2011
                            • 41
                            i still got the same error. Now i want ask you. Maybe i do wrong in config.props
                            i not very clear about this script
                            #define here your connection string for each database
                            #jdbc:mysql://[hostort],[hostort].../[database]
                            if i want to monitor my localhost mysql, what suppose i should do.
                            i replace with this script
                            jdbc:mysql://127.0.0.1:10051/zabbix
                            how about this?
                            ZABBIX.Url=jdbc:mysql://monitor.ente.regione.emr.it:3306/zabbix
                            • dalle
                              • Mar 2009
                              • 402
                              #15
                              how about this?
                              ZABBIX.Url=jdbc:mysql://127.0.0.1:3306/zabbix
                              10051 is the port of Zabbix and it has nothing to do with mysql
                              Andrea Dalle Vacche
                              e-mail:
