Monitor OpenVZ Container
  • BDiE8VNy
    • Apr 2010
    • 680
    this thread describes how one can easily monitor memory resources of OpenVZ hardware nodes and virtual private servers (Containers) via a Zabbix-Agent.
    All information are taken from the "User Beancounters" table and by the output of the utility 'vzmemcheck'.
    Items based on the User Bencounters table are valid for the hardware nodes and containers.
    Items based on 'vzmemcheck' are only valid on hardware nodes.
    [root@zabbix /]# cat /proc/user_beancounters
    Version: 2.5
           uid  resource           held    maxheld    barrier      limit    failcnt
          113:  kmemsize        4620836    5669253    7573026    7756526          0
                lockedpages           0          0         32         32          0
                privvmpages       42262      83619     122713     127136          0
                shmpages          10230      10230      24833      24833          0
                dummy                 0          0          0          0          0
                numproc              52         63         80         80          0
                physpages         15437      55627          0 2147483647          0
                vmguarpages           0          0      92672 2147483647          0
                oomguarpages      15566      55723      84090 2147483647          0
                numtcpsock           30         47        106        106          0
                numflock              3          5        100        100          0
                numpty                1          1         16         16          0
                numsiginfo            0         24        256        256          0
                tcpsndbuf         51520     199360     692906     897706          0
                tcprcvbuf             0     214400     476330     681130          0
                othersockbuf       2240      18816     132096     336896          0
                dgramrcvbuf           0      16768     132096     132096          0
                numothersock          4         10         80         80          0
                dcachesize            0          0    1048576    1048576          0
                numfile             741        936       2048       2048          0
                dummy                 0          0          0          0          0
                dummy                 0          0          0          0          0
                dummy                 0          0          0          0          0
                numiptent            14         14        128        128          0
    [root@zabbix /]#
    [root@ovzhn1 ~]# vzmemcheck
    Output values in %
     LowMem  LowMem     RAM MemSwap MemSwap   Alloc   Alloc   Alloc
       util  commit    util    util  commit    util  commit   limit
       7.95   20.64   60.74   20.33   75.11   57.80   86.55  141.26
    [root@ovzhn1 ~]#
    Because the User Beancounters and the vzmemcheck files are only accessible/executable as user 'root' and the Zabbix-Agent (should) run as unprivileged user 'zabbix', one has to allow the user 'zabbix' access to them via a sudo rule.
    Run the command 'visudo' and add the following lines at the end of the file:
    ## Allow zabbix access to OpenVZ's resources
    Cmnd_Alias MON_OVZ_HN = /usr/sbin/vzmemcheck, /usr/sbin/vzmemcheck -A
    Cmnd_Alias MON_OVZ_UBC = /usr/bin/tac /proc/user_beancounters
    Defaults:zabbix !requiretty
    zabbix ALL = NOPASSWD: MON_OVZ_HN, MON_OVZ_UBC
    Then add the following lines to the agent's configuration file (/etc/zabbix/zabbix_agentd.conf):
    ### Parameter for monitoring OpenVZ resources
    UserParameter=openvz.ubc[*],/usr/bin/sudo /usr/bin/tac /proc/user_beancounters | awk '/$1/{print $(NF-5+$2);exit}'
    UserParameter=openvz.vzmemcheck.putil[*],/usr/bin/sudo /usr/sbin/vzmemcheck | awk '/[0-9]/{print $$$1}'
    UserParameter=openvz.vzmemcheck.util[*],/usr/bin/sudo /usr/sbin/vzmemcheck -A | awk '/[0-9]/{print $$$1;exit}'
    Beginning with XML file "zbx_OpenVZ-0.10.xml" the use of sudo decribed above can be extremly reduced. The drawback with the following alternative way of UBC monitoring is that there is no individual access to a single metric anymore. The template is extended by one additional Item 'Update copy of UBC table' (all other items are the same as in version 0.9) which copies the hole UBC table to a file which is accessible by user zabbix. This way all UBC Items can parse the table directly:
    ## Allow zabbix access to OpenVZ's resources (zbx_OpenVZ-0.10.xml only)
    Cmnd_Alias MON_OVZ_UBC = /usr/bin/install -o zabbix -g zabbix -m 440 /proc/user_beancounters /var/local/zabbix/log/user_beancounters
    zabbix ALL = NOPASSWD: MON_OVZ_UBC, MON_OVZ_HN
    ### Parameter for monitoring OpenVZ resources (zbx_OpenVZ-0.10.xml only)
    UserParameter=openvz.updateubc,/usr/bin/sudo /usr/bin/install -o zabbix -g zabbix -m 440 /proc/user_beancounters /var/local/zabbix/log/user_beancounters && echo Update succeeded || echo Update failed
    UserParameter=openvz.ubc[*],/usr/bin/tac /var/local/zabbix/log/user_beancounters | awk '/$1/{print $(NF-5+$2); exit}'
    UserParameter=openvz.vzmemcheck.putil[*],/usr/bin/sudo /usr/sbin/vzmemcheck | awk '/ *[0-9]/{print $$$1}'
    UserParameter=openvz.vzmemcheck.util[*],/usr/bin/sudo /usr/sbin/vzmemcheck -A | awk '/ *[0-9]/{print $$$1;exit}'
    After restarting the Zabbix-Agent one can create items of type 'Zabbix Agent' and the desired key.
    To get the current usage (held) of the resource 'numproc' use the following key definition:
    openvz.ubc[numproc,1]
    To get the fail count of the resource 'numproc' use the following key definition:
    openvz.ubc[numproc,5]
    To get the allocated memory (Alloc util) by all virtual servers on a hardware node in % use the key:
    openvz.vzmemcheck.putil[6]
    The attached XML file provides two templates for OpenVZ:
    • The first template 'OpenVZ' consists of the complete set of values from the UBC table and triggers for raised fail count as well as virtual network interface.
    • The second template 'OpenVZ Node' consists of all values from vzmemcheck in % and MB as well as triggers for critical utilization.
  • rbenea
    • Apr 2008
    • 35
    Congrats! I was looking for something like this for a while. I hope to have time to test it soon.
    Keep up the good work,
    Rares
