Robots for applications?
  • EricWebb
    • Jan 2006
    • 11
    Is anyone using any sort of robot that runs a command-line program or opens a telnet session, simulates user input, and reads screen responses to determine if an application is running? I've seen (and understand) techniques using wget for web-driven apps, but this one is a command-line app that users telnet into.
  • Markus
    • Jan 2006
    • 39
    You could run a script* that telnets into a site every few minutes and stores the outcome (success/failure) somewhere. Another Zabbix controlled script could then pick up this data asynchronously.
    In fact I am currently working (draft stage) on such a mechanism for various protocols.
    Markus
    * in Expect or Python/telnetlib or maybe Perl
    • elkor
      • Jul 2005
      • 299
      yeah I was going to suggest trying Expect.
      it's relatively quick and simple to deal with, especially if you don't have a particuarly complicated application. And, it can be nested in shell scripts pretty easily.
      • stritec
        • Mar 2005
        • 13
        Use Expect
        I would use expect.
        We have a DSL Connection to the outside world, and we have zabbix monitor that we can get to www.yahoo.com. If the ping cannot get out, then we assume there's a problem with our DSL Connection.
        I have a very simple Expect script which logs into the router via telnet, then issues the system command, and selects restart, and the router restarts.
        Very simple, and easy because of expect.
        • desertrate77
          • Mar 2006
          Still a good idea...every thought about Pexpect?
          Still sounds like a very useful idea. Has anyone tried it so far? One idea might be to combine the python idea and the Expect idea, with something like Pexpect (http://pexpect.sourceforge.net/). Power of python, flexibility of Expect.
