Monitoring HylaFAX plugin
  • muratkoc
    • Mar 2008
    • 23
    Here is the basic HylaFAX plugin, with this plugin yo can monitor these items;
    Number of successfully received pages
    Spent Time while receiving pages
    Average transfer rate of receiving pages
    Number of errors occured while receiving pages
    Number of incoming fax senders
    Number of successfully sent pages
    Spent time while sending pages
    Average transfer rate of sending pages
    Number of errors occured while sending pages
    Number of outgoing fax senders
    this script will give the values right before 1 min ago from it's execution and you can change this interval in the script but don't forget the sync the item's interval.
    If necessary add zabbix user to the sudoers file to execute xferfaxstats and recvstats commands.
    1-) Download the script and rename it to check_hylafax.sh
    2-) Copy to /home/zabbix/bin/check_hylafax.sh on the hylafax server
    3-) Add user parameter like that
    UserParameter=hylafax[*],/home/zabbix/bin/check_hylafax.sh $1
    4-) add items like hylafax[ReceivedPages], hylafax[SentPages] and hylafax[ReceivedError] etc.
    Will add template later.
    Hope this helps,
  • etb
    • Nov 2014
    Item configuration
    Hi Murat,
    Thanks for this script. Did you ever make a template?
    I have this script running via sudoers on the hylafax server, but I think I'm having an issue with Item setup on the zabbix server.
    How should this Item be set up within Zabbix?
    Thanks again!
