Retex PDU´s monitoring
  • vzanchettin
    • Jul 2011
    How to monitor and collect data(Electric Current, Temperature and Humidity) of your datacenter with Retex Smart Monitor and ZABBIX, I used the PDU Retex to monitor.
    It´s very easy, the Template and script I put on the forum.
    If you have any question, you can to contact with me.
    You can to use this Template and External Script, you need to put the external script in your ExternalScripts archive.
  • ajonnalagadda
    • Apr 2013
    I am getting this error when i am configuring the APc PDu
    Created: Application "Current" on "PDU In QTS".
    Created: Application "System" on "PDU In QTS".
    Created: Application "Temperature" on "PDU In QTS".
    Created: Application "Umidity" on "PDU In QTS".
    Cannot find host interface on " HOst NAME (DNS Entry )" for item key
    "status.port1".
    Can you help on the configuration onthis.
