A few people have asked if there is a way to show weather or not you can show how much a process is talking on the network. By default Linux does not have any process accounting for data like this. However SystemTap is one way to accomplish this.
Here is a sample of the output from a SystemTap script I wrote for this:
SystemTap is a project started by Red Hat to allow for low level instrumentation of various aspects of a running Linux system. Presently it is available for most Linux Distributions. SystemTap scripts need to be compiled into a kernel module before they can be used. On RHEL based systems you will need the systemtap, kernel-debuginfo, kernel-devel and gcc packages to compile the kernel module. However once compiled this module can be taken to another machine with the same kernel revision. All this system will need is the systemtap-runtime package installed.
To compile and run the module:
The script itself (saved as zabbix.stp):
I leave it up to anyone interested to write the appropriate userparameter scripts needed. :-) If anyone wants to also contribute a template as well that would be awesome.
*NOTE* You, the end user of this script are responsible for any risk for use in production environments.
COMMAND DEV XMIT_PK RECV_PK XMIT_KB RECV_KB swapper eth1 2425 5644 138 6702 firefox eth1 2847 3897 354 4501 X eth1 77 162 4 191 zabbix_agentd lo 16 16 1 0 zabbix_server lo 8 8 0 0 lxpanel eth1 12 17 0 18 scsi_eh_1 eth1 10 25 0 32 ata/0 eth1 10 24 0 31 vmtoolsd eth1 2 19 0 23 gconfd-2 eth1 10 11 0 12 vmware-user-loa eth1 3 5 0 3 swapper eth2 0 5 0 0 zabbix_agentd eth1 3 5 0 4 vmmemctl eth1 0 7 0 9 udisks-daemon eth1 1 2 0 2 firefox eth2 0 1 0 0 lxterminal eth1 0 1 0 1 hald-addon-stor eth1 1 1 0 1 kswapd0 eth1 1 1 0 0 openbox eth1 0 1 0 0 zabbix_server eth1 0 1 0 1
# stap -m zabbix zabbix.stp
#SystemTap script for Zabbix
#*NOTE* You, the end user of this script, are responsible for any risks
#associated with using this script.
#Compile string:
#Information can be found in /proc/systemtap/zabbix/*
#Current process statistics are found in network
#clear_on_read sets weather or not the statistics are reset when read
# the default is 0.
#The network file is limited to 4096 bytes in size
global ifxmit, ifrecv
global ifmerged
global clear_on_read
probe begin
clear_on_read=0
probe netdev.transmit
ifxmit[dev_name, execname()] <<< length
probe netdev.receive
ifrecv[dev_name, execname()] <<< length
probe procfs("clear_on_read").read
$value=sprintf("%u",clear_on_read)
probe procfs("clear_on_read").write
clear_on_read=strtol($value,2)
probe procfs("network").umask(0444).read.maxsize(4096)
$value=sprintf("%-15s %-7s %7s %7s %7s %7s\n",
"COMMAND", "DEV", "XMIT_PK", "RECV_PK",
"XMIT_KB", "RECV_KB")
foreach ([dev, exec] in ifrecv) {
ifmerged[dev, exec] += @count(ifrecv[dev,exec]);
foreach ([dev, exec] in ifxmit) {
ifmerged[dev, exec] += @count(ifxmit[dev,exec]);
foreach ([dev, exec] in ifmerged-) {
n_xmit = @count(ifxmit[dev, exec])
n_recv = @count(ifrecv[dev, exec])
$value.=sprintf("%-15s %-7s %7d %7d %7d %7d\n",
exec, dev, n_xmit, n_recv,
n_xmit ? @sum(ifxmit[dev, exec])/1024 : 0,
n_recv ? @sum(ifrecv[dev, exec])/1024 : 0)
if (clear_on_read)
delete ifxmit
delete ifrecv
delete ifmerged
