VmBix: vsphere monitoring
  • c.mammoli
    • Feb 2012
    • 48
    #16
    I tried with the very latest version of ESXi and vSphere 5.1
    • Kryol
      • Feb 2011
      • 70
      #17
      If i run with
      $ vmbix -P 12050 -u username -p password -s https://vcenter.mycompany.com/sdk
      all works fine
      But if I try to use
      $ vmbix -c /etc/vmbix/vmbix.conf -f /var/run/vmbix.pid
      I get
      creating pid file /var/run/vmbix.pid 32525
      RemoteException: java.rmi.RemoteException: VI SDK invoke exception:java.net.ConnectException: Connection refused
      If I start as daemon I get same result.
      I think vmbix does not read config.
      Any suggestions
      It was my typo in config. Problem have been resolved
      • Kryol
        • Feb 2011
        • 70
        #18
        Vmbix write a lot of messages to log such as:
        Feb 21 15:41:35 s-vm-vma vmbixd: thread created, collecting data in 1 threads
        Feb 21 15:41:37 s-vm-vma vmbixd: thread  closed, collecting data in 0 threads
        Feb 21 15:41:38 s-vm-vma vmbixd: thread created, collecting data in 1 threads
        Feb 21 15:41:39 s-vm-vma vmbixd: thread created, collecting data in 2 threads
        Feb 21 15:41:40 s-vm-vma vmbixd: thread  closed, collecting data in 1 threads
        Feb 21 15:41:41 s-vm-vma vmbixd: thread  closed, collecting data in 0 threads
        Feb 21 15:42:35 s-vm-vma vmbixd: thread created, collecting data in 1 threads
        Feb 21 15:42:37 s-vm-vma vmbixd: thread  closed, collecting data in 0 threads
        Feb 21 15:42:38 s-vm-vma vmbixd: thread created, collecting data in 1 threads
        Feb 21 15:42:39 s-vm-vma vmbixd: thread created, collecting data in 2 threads
        Feb 21 15:42:40 s-vm-vma vmbixd: thread  closed, collecting data in 1 threads
        Feb 21 15:42:41 s-vm-vma vmbixd: thread  closed, collecting data in 0 threads
        Feb 21 15:43:35 s-vm-vma vmbixd: thread created, collecting data in 1 threads
        Feb 21 15:43:37 s-vm-vma vmbixd: thread  closed, collecting data in 0 threads
        Feb 21 15:43:38 s-vm-vma vmbixd: thread created, collecting data in 1 threads
        Feb 21 15:43:39 s-vm-vma vmbixd: thread created, collecting data in 2 threads
        Feb 21 15:43:40 s-vm-vma vmbixd: thread  closed, collecting data in 1 threads
        I would like to see error messages only. Is it possible?
        • gavind
          • Mar 2013
          • 59
          #19
          I think you need to do some filtering. Have you found out how to do this yet?
          • Kryol
            • Feb 2011
            • 70
            #20
            I turned off such logging
            • aleksardain
              • Feb 2013
              • 19
              #21
              I am currently undertaking the supervison of VMWare with VMBix only I meet some difficulties, so I want to know:
              is there a configuratin bring VMWare side, or all the manipulation is done only on zabbix server?? In the configuration file vmbix.conf line "serviceurl" what does it get??
              wxhen vmbixd the startup of service, I get an error on the demon message
              Starting vmbixd $ / etc / init.d / vmbixd: 37: / etc / init.d / vmbixd: daemon: not found
              and I can not locate the problem to solve.
              i'm Stuck and I can not find a solution. Thank you for your help!
              • hryamzik
                • Dec 2011
                • 16
                #22
                What OS do you use to run VmBix?
                SDK URL should look like 'https://vcenter.mycompany.com/sdk'. It's mentioned on google code wiki page, please check it out here.
                • aleksardain
                  • Feb 2013
                  • 19
                  #23
                  I use Ubuntu 12.04 as OS. For 'https://vcenter.mycompany.com/sdk ', vcenter.mycompany.com = IP address or ESXi vSphere??. Also there is no configuration to do VMWare side??
                  Thanks .
                  • hryamzik
                    • Dec 2011
                    • 16
                    #24
                    There's no configuration on vsphere side required. vcenter.mycompany.com = ip address or dns name of vcenter or esx(i), depending on your configuration.
                    • gavind
                      • Mar 2013
                      • 59
                      #25
                      Does using a port other than the default one make a difference here?
                      • hryamzik
                        • Dec 2011
                        • 16
                        #26
                        No, any port, just don't forget to redirect traffic.
                        • JS86
                          • May 2013
                          • 11
                          #27
                          i get the same error like aleksardain.
                          i use the Zabbix Appliance 2.0.6
                          /etc/init.d/vmbixd: line 37: daemon: command not found
                          • hryamzik
                            • Dec 2011
                            • 16
                            #28
                            Does it work from command line? Show me the arguments you use.
                            • JS86
                              • May 2013
                              • 11
                              #29
                              The last days, yes but at this time i get this:
                              Connected to https://192.168.5.25/sdk, time taken:360ms
                              starting server on port
                              Usage:
                              vmbix {-P|--port} listenPort {-s|--serviceurl} http[s]://serveraddr/sdk {-u|--username} username {-p|--password} password [-f|--pid pidfile]
                              or
                              vmbix [-c|--config] config_file [-f|--pid pidfile]
                              java.net.BindException: Address already in use
                              Shutting down
                              disconnected
                              Shutted down
                              But the init script does not work at any time.
                              • JS86
                                • May 2013
                                • 11
                                #30
                                chkconfig --add vmbixd
                                insserv: script jexec is broken: incomplete LSB comment.
                                insserv: missing `Required-Stop:' entry: please add even if empty.
                                insserv: warning: script 'zabbix_appliance_postboot' missing LSB tags and overrides
                                insserv: Default-Start undefined, assuming default start runlevel(s) for script `zabbix_appliance_postboot'
                                Note: This output shows SysV services only and does not include native
                                systemd services. SysV configuration data might be overridden by native
                                systemd configuration.
                                This is ok:
                                zabbix_get -s localhost -p 12050 -k esx.cpu.load[******,used]
                                1494
