Init script for sles9 + unprivileged mode
  • Avatar
    • Jun 2005
    • 19
    SERVER
    #!/bin/bash
    # chkconfig: - 55 45
    # description: zabbix_server
    # probe: false
    . /etc/rc.status
    # Check that networking is up. If you are running without a network, comment this out.
    #[ "${NETWORKING}" = "no" ] && exit 0
    RETVAL=0
    USER=zabbix
    progdir="/opt/zabbix/bin/"
    prog="zabbix_server"
    pidfile="/var/run/zabbix/zabbix_server.pid"
    start() {
    # Start daemons.
    if [ -f $pidfile ]; then
    if ps `cat $pidfile` >/dev/null; then
    echo -n "$prog: already running"
    echo -n $"$prog start"
    false
    rc_status -v
    exit
    else
    rm -f $pidfile
    fi
    else
    rm -f $pidfile
    fi
    echo -n $"Starting $prog: "
    # we can't seem to use daemon here - emulate its functionality
    su -c $progdir$prog - $USER
    RETVAL=$?
    usleep 1000
    if [ -z "`/sbin/pidof $progdir$prog`" ]; then
    # The child processes have died after fork()ing, e.g.
    # because of a broken config file
    RETVAL=1
    fi
    [ $RETVAL -ne 0 ] && rc_status -v
    [ $RETVAL -eq 0 ] && touch /var/lock/subsys/$prog && echo -n $"$prog startup" && rc_status -v
    return $RETVAL
    stop() {
    RETVAL=0
    pid=
    # Stop daemons.
    echo -n $"Stopping $prog: "
    pid=`cat $pidfile`
    if [ "$pid" ]; then
    kill $pid
    else
    echo -n $"$prog stop"
    rc_status -v
    return 1
    fi
    RETVAL=$?
    [ $RETVAL -eq 0 ] && rm -f /var/lock/subsys/$prog && echo $"$prog stop" && rc_status -v
    echo
    return $RETVAL
    restart() {
    stop
    # wait for forked daemons to die
    usleep 1000000
    start
    # See how we were called.
    case "$1" in
    start)
    start
    stop)
    stop
    restart)
    restart
    echo $"Usage: $0 {start|stop|restart}"
    exit 1
    esac
    exit $?
    AGENT
    #!/bin/bash
    # description: zabbix_agentd
    # probe: false
    . /etc/rc.status
    RETVAL=0
    prog="zabbix_agentd"
    pidfile="/var/run/zabbix/zabbix_agentd.pid"
    start() {
    # Start daemons.
    false
    rc_status -v
    exit
    else
    rm -f $pidfile
    fi
    else
    rm -f $pidfile
    fi
    usleep 1000
    if [ -f /var/run/zabbix/$prog.pid ]; then
    ps `cat /var/run/zabbix/$prog.pid` >/dev/null
    else
    false
    fi
    rc_status -v
    if [ $RETVAL -eq 0 ]; then
    fi
    return $RETVAL
    stop() {
    RETVAL=0
    pid=
    # Stop daemons.
    pid=`cat $pidfile`
    if [ -n "$pid" ]; then
    kill $pid
    else
    rc_status -v
    return 1
    fi
    RETVAL=$?
    echo
    return $RETVAL
    restart() {
    stop
    sleep 2
    start
    case "$1" in
    start)
    start
    stop)
    stop
    restart)
    restart
    exit 1
    esac
    exit $?
