Hello all,
Here is a powershell (2.0) script I made to install zabbix agents on remote servers from a central location. This script can install on one or multiple remote servers.
I tried to put in as much error handling as I could think of. I hope this is useful to someone.
The zabbix agent installation folder that the script will copy over must be put in somewhere accessible from the central server and must have the following hierarchy:
for example, mine is:
and there are these subfolders(only 1 of which is relevant, the most recent):
Under the version subfolder is the regular Windows Zabbix Agent content such as the zabbix_agentd.win.conf file along with the subfolders win32 and win64.
The script handles the architecture detection and installs the correct agent.
The .conf file has only the zabbix server configured. But this is only relevant to me, do whatever you like for your installations.
Here is the script:
Hope this helps!
<DRIVE>:\<ZabbixFolder>\<Version>
O:\Zabbix
O:\Zabbix\1.8.10 O:\Zabbix\2.0 O:\Zabbix\2.0.3
Here is the script:
# NAME: Zabbix_InstallAgent.ps1
# AUTHOR: Pierre-Emmanuel Turcotte,
# DATE : 2012-11-05
# COMMENT: Remote installation of Zabbix agent from central location.
# The zabbix source folder is a folder containing subfolder corresponding to the
# different agent versions. These subfolders contain the win32 and win64 subfolders
# along with the zabbix_agentd.win.conf configuration file.
# You must have administrative priviledges on the remote computers you will specify
# in the computerName parameter. You can either use the following format:
# zabbix_installagent.ps1 -ComputerName server1,server2,server3
# or do not specify any servers, you will be prompted for servers, one at a time.
# Additionnally, you have the following parameters you can optionally define:
# -ZabbixVersion #Version of the agent to be installed(points to subfolder)
# Defaults to "2.0.3"
# -ZabbixPath #Folder where the agent installation resides on the central
# server. This is the folder that will be copied over to the
# remote locations.
# Defaults to "O:\Zabbix"
# About the zabbix path, on my installation, this folder holds 3 subfolders:
# O:\Zabbix
# \1.8.10
# \2.0
# \2.0.3
# $ZabbixPath and $ZabbixVersion will be assembled in a new variable named
# $ZabbixSource, look for it for a better undestanding.
# DISCLAIMER
# The sample script provided here are not supported by Pierre-Emmanuel Turcotte or his
# employer. All scripts are provided AS IS without warranty of any kind. Pierre-Emmanuel
# Turcotte and his employer further disclaims all implied warranties including, without
# limitation, any implied warranties of merchantability or of fitness for a particular
# purpose. The entire risk arising out of the use or performance of the sample scripts
# and documentation remains with you. In no event shall Pierre-Emmanuel Turcotte or his
# employer, its authors, or anyone else involved in the creation, production, or delivery
# of the scripts be liable for any damages whatsoever (including, without limitation,
# damages for loss of business profits, business interruption, loss of business information,
# or other pecuniary loss) arising out of the use of or inability to use the sample scripts
# or documentation, even if Pierre-Emmanuel Turcotte or his employer has been advised of the
# possibility of such damages.
# Parameters
[CmdletBinding()]
Param(
[Parameter(Mandatory=$True,Position=1)]
[array]$computerName,
[string]$ZabbixPath = "O:\Zabbix",
[string]$ZabbixVersion = "2.0.3"
# Initialization
$ZabbixService = "Zabbix Agent"
$ZabbixSource = "$ZabbixPath\$ZabbixVersion"
$instOk
$instBad
# Welcome message
Write-Host "================================================================================"
Write-Host " Welcome!"
Write-Host " This script requires administrative privileges on all implicated servers!"
# Verifying the source installation folder
Write-Host " Zabbix source installation folder:" $ZabbixSource
if (!(Test-Path $ZabbixSource))
Write-Host " "
Write-Host "########################################"
Write-Host "# Error! - Folder does not exist! #"
Write-Host " "
exit
# Execute actions for each server in list
foreach($computer in $computerName)
$zabbixDestination = "\\$computer\C$\Zabbix\"
$ZabbixServiceState = $false
If ((Test-Connection $computer -quiet -count 1))
# Server pings!
Write-Host $computer "is available"
# Verify if service is present...
# Negative response may be caused by the absence of service (good!) or lack of priviledges (bad!)
if (Get-Service -ComputerName $computer -Name $ZabbixService -ErrorAction SilentlyContinue)
# Zabbix Agent is present!
# Bool. Get service state!
$ZabbixServiceState = ((Get-Service -ComputerName $computer -Name $ZabbixService).status -ne "Stopped")
# Verify service state! Stop if necessary!
if ($ZabbixServiceState)
# Zabbix agent present and started!
try
Write-Host " Stopping Zabbix Agent..."
Set-Service -ComputerName $computer -Status Stopped -Name $ZabbixService -ErrorAction Stop
Start-Sleep -Seconds 3
catch
Write-Host " $computer - Zabbix agent could not be installed!"
Write-Host " Service operation error!" $_
$instBad += $computer + " "
Continue # Next server!
Write-Host " Zabbix service stopped."
Write-Host " Install new agent..."
else
Write-Host " Service $ZabbixService on $computer is stopped." # Ok!
else
Write-Host " Service $zabbixAgent not found." # Ok!
Write-Host " Install Zabbix agent..."
# Copy over zabbix folder, make sure no FW could block this
try
# If folder exists, it will be overwritten.
# At this point, service should've been stopped...
Copy-Item -Recurse $ZabbixSource $zabbixDestination -Force -ErrorAction Stop
Write-Host " Copying folder..."
catch
Write-Host " Make sure you have administrative rights on target!"
Write-Host " Copy error!" $_
continue # Next Server
Write-Host " Folder successfully copied!" # No catch triggered, so far so good...
# At this point, the service state has been determined and the folder has been copied to, rights should not be an issue...
# Let's install...
### Get architecture x86 or x64...
try
$os= Get-WMIObject -Class win32_operatingsystem -ComputerName $computer -ErrorAction Stop
catch
Write-Host " -- Make sure you have administrative rights!"
Write-Host " -- Make sure no firewall is blocking communications!"
Write-Host " Error!" $_
continue
if($os.OSArchitecture -ne $null)
# Architecture can be determined by $os.OSArchitecture...
if ($os.OSArchitecture -eq "64-bit")
Write-Host " 64bit system detected!"
$osArch = "win64"
elseif($os.OSArchitecture -eq "32-bit")
Write-Host " 32bit system detected!"
$osArch = "win32"
else
Write-Host " Unknown architecture! Operation Canceled..."
Write-Host $osArch
continue
else
Write-Host " Windows Pre-2008"
# Here have to analyze $os.Caption to determine architecture...
if($os.Caption -match "x64")
$osArch = "win64"
else
$osArch = "win32"
### Architecture detection ended.
### Begin installation...
try
# Create uninstall string
Write-Host " Create uninstall string..."
$exec = "c:\zabbix\" + $zabbixVersion + "\" + $osArch + "\zabbix_agentd.exe -c c:\zabbix\" + $zabbixVersion + "\zabbix_agentd.win.conf -d"
# Execute uninstall string
Write-Host " Execute uninstall string..."
$remoteWMI = Invoke-WMIMethod -Class Win32_Process -Name Create -Computername $computer -ArgumentList $exec
Start-Sleep -Second 3
if ($remoteWMI.ReturnValue -ne 0)
# Oops...
Write-Host " Problem while uninstalling previous zabbix agent! Cancelling..."
Write-Host " Error:" $remoteWMI.ReturnValue
Write-Host " 0 Successful Completion"
Write-Host " 3 Insufficient Privilege"
Write-Host " 8 Unknown Failure"
Write-Host " 9 Path Not Found"
Write-Host " 21 Invalid Parameter"
continue
catch
Write-Host $_
continue
try
# Create install string
Write-Host " Create install string..."
$exec = "c:\zabbix\" + $zabbixVersion + "\" + $osArch + "\zabbix_agentd.exe -c c:\zabbix\" + $zabbixVersion + "\zabbix_agentd.win.conf -i"
# Execute install string
Write-Host " Execute install string..."
# Oops...
Write-Host " Problem while installing new agent! Cancelling..."
Write-Host " Error: " $remoteWMI.ReturnedValue
continue
catch
Write-Host $_
continue
try
# Create run string
Write-Host " Create run string..."
$exec = "c:\zabbix\" + $zabbixVersion + "\" + $osArch + "\zabbix_agentd.exe -c c:\zabbix\" + $zabbixVersion + "\zabbix_agentd.win.conf -s"
# Execute run string
Write-Host " Execute run string..."
# Problème...
Write-Host " Problem while starting the agent! Cancelling..."
continue
catch
Write-Host $_
continue
### Installation end...
### Start verification
try
$InstallStatus = Get-Service -ComputerName $computer -Name $ZabbixService
catch
Write-Host " Problem while verifying service!"
Write-Host " Error! " $_
continue
if ($InstallStatus.Status -eq "Running")
Write-Host " Service installed and started!"
else
Write-Host " Service installed but not started!"
Write-Host " Service state: " $InstallStatus.Status
$instOk += $computer + " "
Else
Write-Host $computer "is not available! Skipping!"
Write-Host " SCRIPT FINISHED!"
Write-Host " Successful installations: " $instOk
Write-Host " Unsuccessful installations: " $instBad
Write-Host " "
Write-Host " Press any key!"
$waitForIt = $host.UI.RawUI.ReadKey("NoEcho,IncludeKeyDown")
exit 0
