Another way for PostgreSQL partitioning
  • BDiE8VNy
    • Apr 2010
    • 680
    This is yet another way for partitioning PostgreSQL relations.
    The code is a result of playing around with PL/pgSQL and is inspired by the the solution provided in the Wiki.
    Usage:
    SELECT create_zbx_partitions();       -- Create partitions for next month
    SELECT create_zbx_partitions(2);      -- Create partitions for the next-but-one month
    SELECT create_zbx_partitions(-10,12); -- Create partitions beginning from 10 month ago to next-but-one month
    SELECT list_zbx_partitions();       -- List  partition for current month
    SELECT list_zbx_partitions(2);      -- List partitions for the next-but-one month
    SELECT list_zbx_partitions(-10,12); -- List partitions beginning from 10 month ago to next-but-one month
    SELECT drop_zbx_partitions();       -- Drop partitions for last month
    SELECT drop_zbx_partitions(2);      -- Drop partitions for the next-but-one month
    SELECT drop_zbx_partitions(-10,12); -- Drop partitions beginning from 10 month ago to next-but-one month
  • Colttt
    • Mar 2009
    • 878
    and what is the difference between yours and THIS odr THIS
    Debian-User
    Sorry for my bad english
    • BDiE8VNy
      • Apr 2010
      • 680
      roughly:
      - insert fails if partition does not exist
      - partition interval is defined to a fixed range - like monthly
      - no condition evaluation on inserts
      - no additional select on inserts
      • alledm
        • May 2012
        • 84
        the partition creation would be scheduled right?
        Why would you want the insert to fail if the table is not there?
        Also, do you have daily partitions as well?
        Regards
        Alessandro
        • BDiE8VNy
          • Apr 2010
          • 680
          Yes, the partition maintenance is scheduled via pgAgent.
          It's a smart idea to implement automated partition/table creation within the insert trigger.
          However, the process for partition maintenance has to be reliable. If set up and monitored correctly there can't be the case of a missing partition/table.
          I don't like to use triggers but in PostgreSQL (except using EnterpriseDB) there is no other way to achieve something similar to partitions. Therefore I personally want to have as less and simple code within the triggers as possible and let the maintenance be done by a decoupled process.
          One can partition in any kind of period. Just change the code accordantly.
