Template for Cisco SG500 28 Port
  • managenet
    Hi All,
    Thought I would share a tip on building a template for a Cisco SG500 28 port switch. I based my new template on the one posted on the Wiki for the Cisco SF300 -24 port (Cisco_SF300-24P.xml)
    After some initial frustration in not getting any data from the interface items, what i discovered was that this switch numbers the OID's for the ports at 49 rather than 1. So you just need to modify the interface numbers of the corresponding OID's in the template by adding 48 to the interface number.
    So for instance, instead of:
    Description: Port 01 Traffic IN
    Key: ifInOctects.1
    OID: .1.3.6.1.2.1.2.2.1.10.1
    it should be:
    Key: ifInOctects.1
    OID: .1.3.6.1.2.1.2.2.1.10.49
    ..and so on....
    The attached template is for the Cisco SG500-28P 28-Port Gigabit PoE Stackable Managed Switch and has been modified as described, as well as adding the additional items and graphs for ports 1 - 28
    Enjoy!
  • jsosic
    • Apr 2008
    • 47
    Thank you very very much!
    I will try this template and see how it works. Eventually convert it to LLD
    • bbrendon
      • Sep 2005
      • 873
      FYI. This template doesnt have any SGXXX feature specific OIDs so dont waste your time if thats what you're looking for.
      Unofficial Zabbix Expert
      Blog, Corporate Site
      • othin
        • May 2016
        • 14
        Hi all (a year later)
        If is possibile i want use this thread because i'm searching a template for a cisco sg500 but 52 port...there is one ?
        I really need for monitoring the temperature (i tried with this templater 28 ports but i don't see nothing)
        Anyone can help me plz? thx
        • bbrendon
          • Sep 2005
          • 873
          This is the only non standard OID i've got for SG series. CPU.
          enterprises.9.6.1.101.1.8.0
          • othin
            • May 2016
            • 14
            Thanks mate
