Zabbify project on github
  • alledm
    • May 2012
    • 84
    I have developed a little script to integrate (mainly) crontab scripts into Zabbix.
    It basically helps detecting scripts that fail silently and could potentially allow you to remove hundreds of emails from your mailbox
    This is an example of how it can be used.
    crontab -l
    00 05 * * * zabbify "/usr/bin/mysqldump --databases zabbix --single-transaction | /bin/gzip > /opt/backups/mysql/zabbix/zabbix.sql.gz"
    The script will report on the exit status and output back to Zabbix, and raise a trigger if the exit is non 0.
    Obviuosly you can add more triggers attached to exit status and output.
    You will find the script here
    It is written in python and uses zabbix_api and zbxsend.
    Should work in Python > 2.6
    Please feel free to give me your feedback/suggestions.
  • alledm
    • May 2012
    • 84
    although nobody seems to be using it , I wanted to let you know that I have improved the zabbify script.
    It now allows you to set a timeout (in seconds) for a process, and will trigger a notification if the timeout is breached.
    Example:
    0 * * * * zabbify --timeout 60 /usr/bin/script_that_might_hang.sh
    Hope this helps. Please let me know if you use it or if you can think of any other way to improve it.
    Regards
    • crashdump
      • Jun 2013
      Nice idea, thank you for sharing !
