Hello everyone,
I did search over the net for different solution to monitor Zimbra but I did not find any way to monitor the java part of it, and a lot of solution were using crazy shell script anyway.
So I modified the java option of Zimbra from :
to
You then have to create the files "/opt/zimbra/jmxremote/jmxremote.password" and "/opt/zimbra/jmxremote/jmxremote.access" with a user/authorization couple, like this :
Now you have to restart Zimbra.
You will then be able to connect yourself using the Zabbix java gateway to the Zimbra JVM.
You will have access to all the standard beans (java memory parameters, garbage collection, etc) but, and that's the best, you'll also have access to specific Zimbra metric, like the number of IMAP/IMAPS/POP3/POP3S sessions, the number of webmail request and much more.
You don't have everything, but that's one hell of a good start.
You'll find attached 2 template from my Zabbix 2.0.4:
- the first one is for the generic monitoring of java application, working for anything using an Oracle JVM version 6 or 7 (didn't try for others)
- the second one is the specific one for Zimbra, and works perfectly with my Zimbra CE 8.0.2
Feedbacks are of course welcome
OK, I can't upload the files because they are too big... they are on pastebin :
- JMX generic : http://pastebin.com/Sy7esECS
- JMX Zimbra : http://pastebin.com/euaENenj
zimbra@mail:~$ zmlocalconfig mailboxd_java_options mailboxd_java_options = -server -Djava.awt.headless=true -Dsun.net.inetaddr.ttl=60 -XX:+UseConcMarkSweepGC -XX:PermSize=128m -XX:MaxPermSize=128m -XX:SoftRefLRUPolicyMSPerMB=1 -verbose:gc -XX:+PrintGCDetails -XX:+PrintGCTimeStamps -XX:+PrintGCApplicationStoppedTime -XX:-OmitStackTraceInFastThrow -Djava.net.preferIPv4Stack=true
zimbra@mail:~$ zmlocalconfig mailboxd_java_options mailboxd_java_options = -server -Djava.awt.headless=true -Dsun.net.inetaddr.ttl=60 -XX:+UseConcMarkSweepGC -XX:PermSize=128m -XX:MaxPermSize=128m -XX:SoftRefLRUPolicyMSPerMB=1 -verbose:gc -XX:+PrintGCDetails -XX:+PrintGCTimeStamps -XX:+PrintGCApplicationStoppedTime -XX:-OmitStackTraceInFastThrow -Djava.net.preferIPv4Stack=true -Dcom.sun.management.jmxremote -Dcom.sun.management.jmxremote.port=12345 -Dcom.sun.management.jmxremote.ssl=false -Dcom.sun.management.jmxremote.authenticate=true -Dcom.sun.management.jmxremote.password.file=/opt/zimbra/jmxremote/jmxremote.password -Dcom.sun.management.jmxremote.access.file=/opt/zimbra/jmxremote/jmxremote.access
echo "zabbix readonly" > /opt/zimbra/jmxremote/jmxremote.access echo "zabbix [your_password]" > /opt/zimbra/jmxremote/jmxremote.password chmod 600 /opt/zimbra/jmxremote/jmxremote.*
