Using LLD to monitor Linux Processes
  • qix
    • Oct 2006
    • 423
    First off, this is highly experimental. USE AT YOUR OWN RISK!
    I will not be held accountable for any inconvience this might cause to your production servers (see the README for potential pitfalls)
    Now, on to the sweet chocolaty goodness
    Today one of the people in #zabbix (freenode irc) was wondering how to monitor the CPU usage of individual processes on his system.
    He wants to use this info to correlate any CPU spikes to an individual process. This would be looking back after one such event occurs.
    Zabbix does not have a build-in mechanism for this, so we need to get creative.
    The way I see it, there are two approaches to the problem:
    1) Regularly push/poll a text based item containing some ps output including the process CPU and memory usage.
    2) Get the LLD wrench from the toolbox and let Zabbix discover the running processes on the server so we can start graphing.
    I decided to look into the second option
    You can find my solution on github at https://github.com/q1x/zabbix-templates.git (process-discovery)
    Please have a look at the README for some pointers and requirements.
    In this process I also had to create a custom item that will calculate the CPU usage for a process (currently there is no such item in the agent, which I found curious; https://support.zabbix.com/browse/ZBXNEXT-494).
    The UserParameter is included in the README.
    Note that the memory usage monitoring is a bit (very) limited IMHO (see https://support.zabbix.com/browse/ZBX-4532 for more info on that).
    With kind regards,
    Raymond
  • qix
    • Oct 2006
    • 423
    Some screenshots:
    Discovered CPU usage per process
    Discovered memory usage per process
    Discovered number of processes
    With kind regards,
    Raymond
    • BDiE8VNy
      • Apr 2010
      • 680
      ZBXNEXT-1711 (New key for discovery rule / LLD to collect processes) asks for a build-in mechanism for this.
