SNMP traps made easy
  • automaticserver
    • May 2013
    • 10
    Hi all,
    we had the problem to handle SNMP traps with zabbix and we studied several solutions but none of the met our requirements.
    We have a environment with a lot of snmp enabled devices and wanted to migrate this to another monitoring systems. Because we didn't have much time to configure every snmp device inside zabbix, add items and so on, we choosed a simpler approach:
    1) snmptrapd gets the traps
    2) snmptrapd calls a ruby script "zabbix_snmp_trapper.rb" to handle it (ruby because I can write it a lot faster than perl and python and cause of puppet it's everywhere in our environment)
    3) API calls to zabbix to create
    a) a host if non existent
    b) an item for this host, if non existent
    c) an trigger, if non existent
    d) an event through zabbix_sender
    So the process is in short:
    snmptrapd -> zabbix_snmp_trapper -> zabbix_sender->zabbix
    With additional API call from zabbix_snmp_trapper to zabbix.
    In the current state, this solution works but it is not very comfortable to install, some debugging stuff should be better - but we have a small log. You should calculate 1 or 2 hours for install. Most stuff described for RedHat/CentOS only, some steps for Debian too but you can adapt that easily.
  • automaticserver
    • May 2013
    • 10
    Part2
    You need at first ruby and rubygems:
    Debian:
    apt-get install ruby rubygems
    RedHat/CentOS:
    yum install ruby rubygems ruby-devel make gcc binutils
    Install Zabbix-Api-Library for Ruby
    gem install zbxapi
    Patch gem for Zabbix 2.x
    -- /usr/lib/ruby/gems/1.8/gems/zbxapi-0.2.415/zbxapi.rb.old
    2013-05-02 13:59:00.517566061 +0200
    +++ /usr/lib/ruby/gems/1.8/gems/zbxapi-0.2.415/zbxapi.rb
    2013-03-26 15:25:06.726081295 +0100 @@ -283,7 +283,7 @@
    debug(6,:var=>params,:msg=>"Parameters")
         checkauth
    -    checkversion(1,1)
    +    checkversion(2,0)
         params={} if params==nil
         obj=do_request(json_obj(method,params))
    • automaticserver
      • May 2013
      • 10
      Part3
      Install snmptrapd
      yum install net-snmp
      chkconfig snmptrapd on
      Config snmptrapd in /etc/snmp/snmptrapd.conf
      authCommunity   log,execute,net public
      traphandle default /usr/local/bin/zabbix_snmp_trapper.rb
      Place /usr/local/bin/zabbix_snmp_trapper.rb
      wget www.automatic-server.com/zabbix/zabbix_snmp_trapper.rb -O \
      Place /etc/zabbix/snmp_trapper.conf
      LOG_FILE = '/var/log/zabbix/snmp_trapper.log'
      DEFAULT_ZABBIX_GROUP = 'snmp_tmp'
      ZABBIX_URL = 'http://127.0.0.1/zabbix'
      ZABBIX_SERVER = '127.0.0.1'
      ZABBIX_USER = 'zabbixadmin'
      ZABBIX_PASS = 'mysecretpassword'
      You should have an zabbix user present which can access the API. Please
      config this according to your config above or vice versa
      Start snmptrapd
      /etc/init.d/snmptrapd start
      Debug
      tail -f /var/log/zabbix/snmp_trapper.log /var/log/messages
      • automaticserver
        • May 2013
        • 10
        Credentials
        Sponsored by ricardo.ch, Switzerland
        Written by Oliver Schad, Automatic Server AG
        • automaticserver
          • May 2013
          • 10
          Part4
          For proper MIB handling (decode OID numbers to human readable strings), you can place your mib files in RedHat/CentOS in /usr/share/snmp/mibs
          Change your snmp config to use them in /etc/snmp/snmp.conf:
          mibs +ALL
          • Ishan
            • May 2013
            • 40
            Hello
            I am using zabbix 2.0.6 version on cent os box and now i am trying to configure the snmptraps as you mentioned in this document. I have doubt about part 2
            Can you please kindly let me know how did you Patch gem for Zabbix 2.x. If you can please let me know step by step, because i am confuse with this code. Please clarify me kindly.
            Thanks in advance
            Ishan
            • automaticserver
              • May 2013
              • 10
              Ishan
              You should interpret the patch manually, because pathes could be wrong if you have other versions of the gem or another linux distribution.
              Find the file "zbxapi.rb", edit it with your favorite editor, find the line with "checkversion" inside, change it
              original: checkversion(1,1)
              new: checkversion(2,0)
              save the file, that's it.
              • Ishan
                • May 2013
                • 40
                Hi
                Thanks for your super fast reply, but i am unable to find the file called zbxapi.rb in the system, what do i need to do?
                Ishan
                • automaticserver
                  • May 2013
                  • 10
                  You have to install ruby and the Zabbix-Gem:
                  yum -y install ruby rubygems
                  gem install zbxapi
                  • Ishan
                    • May 2013
                    • 40
                    output of them
                    Thanks again ...
                    Here is the result
                    [root@zabbix /]# yum -y install ruby rubygems
                    Loaded plugins: fastestmirror, refresh-packagekit, security
                    Loading mirror speeds from cached hostfile
                    * base: centos.fastbull.org
                    * extras: mirror.vit.com.tr
                    * updates: mirror.vit.com.tr
                    Setting up Install Process
                    Package ruby-1.8.7.352-10.el6_4.i686 already installed and latest version
                    Package rubygems-1.3.7-1.el6.noarch already installed and latest version
                    Nothing to do
                    [root@zabbix /]# gem install zbxapi
                    Building native extensions. This could take a while...
                    ERROR: Error installing zbxapi:
                    ERROR: Failed to build gem native extension.
                    /usr/bin/ruby extconf.rb
                    mkmf.rb can't find header files for ruby at /usr/lib/ruby/ruby.h
                    Gem files will remain installed in /usr/lib/ruby/gems/1.8/gems/json-1.8.0 for inspection.
                    Results logged to /usr/lib/ruby/gems/1.8/gems/json-1.8.0/ext/json/ext/generator/gem_make.out
                    • automaticserver
                      • May 2013
                      • 10
                      Thanks again ...
                      Here is the result
                      Ok, forgot to install devel stuff:
                      yum -y install ruby-devel gcc make binutils
                      gem install zbxapi
                      • Ishan
                        • May 2013
                        • 40
                        Hi Oliver Schad,
                        Thanks you, i was installed successfully..
                        In part 3 you are instructing to Place /etc/zabbix/snmp_trapper.conf,
                        Question 1: that means i need to create a new file?
                        Question 2: that means i need to create a file manually?
                        Question 3: do i need to create a group in zabbix web interface?
                        Please kindly help me to figure out this..
                        Ishan
                        • automaticserver
                          • May 2013
                          • 10
                          Hi Oliver Schad,
                          Yes.
                          No, don't think so. The Script creates that file, but not that directory.
                          Yes.
                          Best regards
                          Oli
                          • Ishan
                            • May 2013
                            • 40
                            Hi Oli
                            Thanks for your help its working now..Thumbs UP......
                            But i am not able to see the snmp_trapper.log file in the directory..but these logs are coming through messages log in log directory. as per your instruction i had run the tail command to get the snmptraps log but it was showing me messages log.
                            Other issue is i am testing with testing server which is connected to the internet, but my production server was not connected to the internet
                            How do i find through the exact RPM package for below commands to run in my production server..
                            gem install zbxapi
                            AND
                            Where is the exactly in snmp.conf to put this code? (mibs +ALL)
                            In zabbix we are receiving these traps as strings right?
                            Those are showing in UP time graphs?
                            Basically how can i give proper graph or report for linkup and link down in interface wise as monthly? (WAN links)
                            I know these are lots of questions, but take your time and give me some help..
                            Your previous answers are all straight forward and correct, that is really appreciated..!!!
                            Ishan
                            • automaticserver
                              • May 2013
                              • 10
                              #15
                              NP
                              Mmh, this should be the logs of the snmptrapd, not the ruby script. Maybe there are some permissions wrong or you have a wrong path inside your config? Could you check the settings of "LOG_FILE" and create the log file manually with "touch" or so?
                              Don't get this what you mean. Could you explain it a little more?
                              You could copy the compiled gem, so you would only need "ruby" and "rubygems". Gems are located in /usr/lib/ruby/gems/ - you can copy the whole tree, you you don't need to do the following:
                              gem install zbxapi
                              /etc/snmp/snmp.conf
                              No, the key is of course a string, but the value is just a numeric 1.
                              No, you don't get a graph, because a graph means you have values with a given frequency, i.e. 1 value per minute. With traps you can't have this behaviour because they appear in sometime or never.
                              What you could do is change the ruby trapper to generate virtual traps with a value of numeric 0 if no real traps arive any minute. But this would be much more effort because you have to fetch all configured traps from the zabbix API and create those virtual traps.
                              In zabbix, you can filter through events per device, but you have to do this on your own. Of course you could make script for it with API calls. But SNMP traps are really strange designed, you have no real relation between interface up and down, you have to know the SNMP OIDs of both events (yes, they are different) and correlate them manually. I don't know any full automatic way for it. Maybe somebody can correct me, if I'm wrong.
                              Best Regards
                              Oli
