Monitoring NTP offset
  • Nolaan
    • Mar 2018
    • 17
    I am new with Zabbix.
    Currently on zabbix server synchronize time from network and from GPS (http://www.rjsystems.nl/en/2100-ntpd...8-lvc-gpsd.php)
    I would like to check clock offset between the Zabbix Server and a remote NTP server, similar to check_ntp_time from Nagios.
    Any advice on how to do it?
  • LenR
    • Sep 2009
    • 1011
    Use your favorite scripting value to get a difference, create a trapper item, update the item with zabbix_sender. Schedule the script with cron. You could use an external script if you wish.
