SSL monitoring with Zabbix
  • szremo
    • Jul 2018
    • 12
    Dear Zabbix forum,
    I would like to share you my solution to monitoring SSL certificate on each website.
    That has been configured based on external check.
    First of all, simple script has been prepared and placed in /externalcheck directory
     root@zabbix:/# cat /etc/zabbix/externalscripts/ssl_valid.sh
    #!/bin/bash
    #Prepared by Marcin 'szremo' Szremski'
    SSL_DATE=$(echo | openssl s_client -servername $1 -connect $1:443 2>/dev/null | openssl x509 -noout -dates | grep notAfter | awk -F = '{ print $2 }' | awk 'BEGIN {OFS = "-"} {print $1,$2,$4}')
    EXPTIME=$(date -d$SSL_DATE +%s)
    TODAY=$(date +"%b-%d-%Y")
    CURRENT=$(date -d$TODAY +%s)
    NUM=$(($EXPTIME - $CURRENT))
    RESULT=$(($NUM/86400))
    echo $RESULT
    Next, template has been prepared which execute that script once per day(value of Update interval): Click image for larger version  Name:	Screenshot 2019-06-11 at 11.24.02.png Views:	1 Size:	63.8 KB ID:	380486
    Pls. note that if your host in Zabbix is different that FQDN of your web site you should replace{HOST.NAME} by FQDN. Last think is to setup a triggers, in my case as on picture below:
    Click image for larger version  Name:	Screenshot 2019-06-11 at 11.26.25.png Views:	1 Size:	53.6 KB ID:	380487
    And result for host called Zabbix.com
    Click image for larger version  Name:	Screenshot 2019-06-11 at 11.27.32.png Views:	1 Size:	11.6 KB ID:	380489
    Click image for larger version  Name:	Screenshot 2019-06-11 at 11.27.44.png Views:	2 Size:	11.8 KB ID:	380490
  • rvanderkooi
    • May 2019
    • 33
    Many thanks! This working perfect for me!
    • sancho
      • Mar 2015
      • 301
      Great!!!!
      Thank you szremo
      • Hamardaban
        • May 2019
        • 2714
        Thanks!
        for FreeBSD:
        #!/bin/sh
        # set locale of date in cert
        LC_ALL=en_GB.UTF-8
        export LC_ALL
        EXPTIME=$(date -j -f "%b-%d-%Y" $SSL_DATE +%s)
        CURRENT=$(date -j +%s)
        echo $RESULT
        • wladimir50
          • Nov 2018
          • 9
          good stuff! working like a dream for me.
          THANKS!
          • alientm
            • Aug 2014
            • 51
            Dziękuję
            • nilldot
              • Aug 2011
              • 21
              Guys, Any chance you could attache the template please ?
              • Alex G
                • Jan 2020
                This is good, but it would be cool to do this in preprocessing on the JS.
                • gofree
                  • Dec 2017
                  • 400
                  I think not as its "preprocessing". Maybe some ugly way with trapper item and after use preporcessing. But I dont think it will be possible with duktape ( javascript engine in zabbix ) what I've googled a bit. I found something for nodejs engine - this doesnt help I guess
                  • rafael.mendes
                    • Dec 2020
                    I have a error in "Last Data"...
                    The error:
                    2020-12-08 00:13:22
                    unable to load certificate
                    140244526622608:error:0906D06C:PEM routines:PEM_read_bio:no start lineem_lib.c:707:Expecting: TRUSTED CERTIFICATE
                    date: invalid date '+%s'
                    -18604
                    • LenR
                      • Sep 2009
                      • 1011
                      You can also parameterize the port if it's not always 443 :-)
                      • DRO
                        • Jan 2022
                        The error:
                        2020-12-08 00:13:22
                        -18604
                        Same problem I have, did you ever fix it?
