Few suggestions
  • ognjen
    • Jan 2019
    • 23
    Few suggestions
    It would be nice to have proper flap detection and Multi tenant access.
  • Alex.S
    • Feb 2012
    • 258
    Would be nice to know what exactly do you mean by "proper" in either case Details, examples?
    • ognjen
      • Jan 2019
      • 23
      Everything went below had some problem with this reply
      • ognjen
        • Jan 2019
        • 23
        I can't edit the previous comment for some reason, i meant to say Well same type of flap detection that Nagios or Icinga or few others have had for a years with a simple GUI tick to enable it per host or group of hosts. Hysteresis seesm to kind of work i will get the examples in AM.
        • ognjen
          • Jan 2019
          • 23
          They way flap protection works in Nagios is that the last 20 state changes or something like that, for every host and/or service are saved. All the states are weighted, with the most recent one being worth the most (1.15) and the 20th the least (0.8) i could be wrong, and this is probably done by someone very smart who decided to build it this way. The final flapping value are the weighted state changes divided by the total count of 20. In terms of hysteresis it basically means having a different condition to go from state B to A then the condition used to go from A to B. To me this kind of works but i find it tedious to setup.
