Build screens fast using API
  • fvdhoeven
    • Apr 2013
    • 11
    I've build a script in python to quickly build a screen from several hosts (or a switch) which uses the API of Zabbix. It can be found here:
    zabbix-screenbuilder
    I had the need for a script like this because I was monitoring some switches with auto discovery of the ports and wanted to display the discovered ports in a screen. Currently that is not possible in Zabbix so i built this script.
    Feel free to improve upon it It was build quickly and maybe not in the most efficient way, but it got the job done.
  • tchjts1
    • May 2008
    • 1605
    I haven't tried it, but I like the concept.
    I can see where this may come in handy.
    • steveboyson
      • Jul 2013
      • 582
      Select hostgroup: 12
      selectHostgroup - Hostgroup selected (hostgroupid: 15, hostgroupname: Physical servers)
      Something went wrong
      Error: addstr() returned ERR
      Traceback (most recent call last):
      File "screenbuilder.py", line 406, in <module>
      main()
      File "screenbuilder.py", line 385, in main
      doMenu(menu)
      File "screenbuilder.py", line 241, in doMenu
      processmenu(menu_data)
      File "screenbuilder.py", line 227, in processmenu
      processmenu(menu['options'][getin], menu) # display the submenu
      File "screenbuilder.py", line 224, in processmenu
      if getin == optioncount:
      UnboundLocalError: local variable 'getin' referenced before assignment
      • fvdhoeven
        • Apr 2013
        • 11
        Python version
        It might have something to do with the python version. I've build and tested (and used) this with version 2.6.6 and on CentOS. I haven't tested this on different versions or platforms.
        • steveboyson
          • Jul 2013
          • 582
          It's a SuSE 12.3 box with Python 2.7.3
          • pgcorchary
            • Dec 2014
            Super! ... but issues
            First of all .. this is SUPER. I have been looking for something like this EXACTLY. I have a 1/2 built script of my own, but the goals were no as ambitious, only to create a screen of one item for all hosts of a named hostgroups.
            Anyway ... I tried your script and got the following.
            Connected to Zabbix API Version: 2.2.3
            File "./screenbuilder.py", line 406, in <module>
            main()
            File "./screenbuilder.py", line 387, in main
            checkScreenGraphs(hostgroupid, hostgroupname, menu)
            File "./screenbuilder.py", line 335, in checkScreenGraphs
            storeScreenGraphs(hostgroupid, hostgroupname, menu_data, screenid)
            File "./screenbuilder.py", line 260, in storeScreenGraphs
            zapi.screenitem.create(screenitem)
            AttributeError: 'ZabbixAPI' object has no attribute 'screenitem'
            It correctly got all HGs, hosts, and items, and at the very last step to build the graph, threw this error as above. Thoughts?
            • fvdhoeven
              • Apr 2013
              • 11
              Will check
              I will have a look at it later today. I'll report back!
              • fvdhoeven
                • Apr 2013
                • 11
                Replaced API library
                I also had some errors when I tried to use it again. In my case I upgraded Zabbix to a newer version and it stopped working. So I downloaded a newer zabbix API library (courtesy of https://github.com/gescheit/scripts/tree/master/zabbix) and then it worked again. I've updated the code on github.
                Hope this helped!
                • steveboyson
                  • Jul 2013
                  • 582
                  Unfortunately, it doesn't work.
                  Connecting to Zabbix API
                  Zabbix API connection failed
                  Additional info: (u'Error -32602: Invalid params., Not authorized while sending {"params": {}, "jsonrpc": "2.0", "method": "APIInfo.version", "id": 1}', -32602)
                  • steveboyson
                    • Jul 2013
                    • 582
                    zabbix_api.py MD5 is
                    00d43d60387cb06c138fce52d6e38704 zabbix_api.py
                    and lives in /usr/lib/python2.7/site-packages/zabbix_api-0.1-py2.7.egg
                    (I downloaded the most current release of the API and installed with "python setup.py install"). The .pyc gets compiled there, though.
                    The example from zabbix_api works (sort of).
                    • fvdhoeven
                      • Apr 2013
                      • 11
                      lib folder
                      My script doesn't use the library you just installed. It uses the library in the lib folder provider with my script. So updating it on your server, won't help.
                      You can however remove this line:
                      sys.path.append('./lib')
                      so that the script does use the API installed on your server, or update the library in the lib folder.
                      • steveboyson
                        • Jul 2013
                        • 582
                        Makes no difference, with none of the available zabbix_api.py screenbuilder works here.
                        • steveboyson
                          • Jul 2013
                          • 582
                          Funny: using the old "zabbix_api.py" (14838 bytes) the program starts, screen_info.py even gives an output.
                          But after configuring some graphs/hosts it bails out with:
                          Do you want to create a screen called "Screenbuilder" with these graphs? (Yes/No): Yes
                          OK
                              main()
                            File "screenbuilder.py", line 387, in main
                            File "screenbuilder.py", line 335, in checkScreenGraphs
                            File "screenbuilder.py", line 294, in storeScreenGraphs
                            File "./lib/zabbix_api.py", line 357, in method
                              return self.universal("%s.%s" % (self.data["prefix"], name), opts[0])
                            File "./lib/zabbix_api.py", line 80, in wrapper
                              return self.do_request(self.json_obj(method, opts))['result']
                            File "./lib/zabbix_api.py", line 364, in do_request
                              return self.parent.do_request(req)
                            File "./lib/zabbix_api.py", line 318, in do_request
                              raise ZabbixAPIException(msg, jobj['error']['code'])
                          zabbix_api.ZabbixAPIException: (u'Error -32500: Application error., Incorrect row span provided for screen element located at X - 0 and Y - 0. while sending {"params": {"resourcetype": 0, "resourceid": "2723", "screenid": "225", "height": "200", "width": "500", "y": 0, "x": 0}, "jsonrpc": "2.0", "method": "screenitem.create", "auth": "2a5a98fb94c6b572f8d1319627f6af10", "id": 13}', -32500)
                          • steveboyson
                            • Jul 2013
                            • 582
                            Updated our Zabbix installation from 2.0.10 to 2.0.13.
                            Still does not work :-(
                            • almirf
                              • Sep 2015
                              • 29
                              #15
                              Dear fvdhoeven
                              Im have a problem, im need to show my screen sorted my values of an item
                              With this API im can do this?
                              im can do for examplle one TOP20 with the best 20 screens that have higher value of incoming traffic ?
                              Almir
