Monitor Hostfile and show differents
  • pa5nt
    • Dec 2019
    • 11
    Hi.
    we use a Host file for a large number of host .
    ik am looking for a way to show the differents when a change is made and trigger and show me the differents.
    the file is hosted on a linux based server which i have acces to.
    the changed to the host file are made bij other persons. ;-)
    thanks Joost .
    • 4996
    Getting a trigger about diff, that's easy... But getting exact differences... that is a problem. vfs.file.contents will get the data and diff wil tell you there is any difference.. but it will not display any actual differencies.. I'm thinking you may need to create a UserParameter for it and solve this locally on host, fetching already prepared data. Needs probably a script which does all the work - have a copy of the file, which is updated, when there are changes and running diff and outputting actual differencies...
    • Ullrich
      • Jul 2021
      Use the Hosts page to better understand important performance metrics MyVanillaCard, like resource usage, network and processes performance, and data about your containers.
