PowerBI and Zabbix Integration
  • spikefishmax
    • Mar 2020
    Check out our quick guide on integrating Microsoft PowerBI and the Zabbix API https://www.spikefishsolutions.com/p...ktop-to-zabbix
    Would love to get your feedback!
  • isaqueprofeta
    • Aug 2020
    • 154
    That's some good stuff!!! Thx man!!!
    I'd just think that you should expand it to explain the logout method, to prevent lot of orphan sessions on database.
    • Spikefish Christi
      Spikefish Christi commented
      Thanks for the feedback! There aren't an actual database connects, I'm using the Zabbix API for the token and the data, so logging out is not necessary.
  • simonma
    • Aug 2021
    Hey, thanks for the post.
    My Zabbix instance is using a self-signed certificate and I can't connect to it from latest version of PowerBI Desktop.
    Error message "DataSource.Error: The underlying connection was closed: Could not establish trust relationship for the SSL/TLS secure channel."
    The certificate is valid.
    I've tried installing the certificate in to local Trusted Root Certificate Authority but it is still unable toconnect.
    • Rahma.S
      • Jun 2021
      • 17
      This is really usefull !
      Great guide.
        Originally posted by TyrelGislason
        Can anyone tell me how can i integrate zabbix with Power BI desktop ? Thank you in advance
        No you should read it from the first post of this thread...
        • mcflurry
          • Jun 2022
          • 32
          I've been using this to connect Power Bi to zabbix.
          spikefishmax could you share how to retrieve items values to create graphs in Power BI for CPU consumption, Memory, Disks... etc.??
          • mcflurry
            • Jun 2022
            • 32
            Uhm, i found out how to get itemids from zabbix and with that it's cheesecake.
