Template for Switch Cisco 3560E
  • renato.souza
    • Nov 2015
    Hi Gents,
    still a work in progress, but already useable.
    GitHub is where people build software. More than 225 million people use GitHub to discover, fork, and contribute to over 800 million projects.
  • renato.souza
    • Nov 2015
    just a little adjustment
    I'll put another one here
    • Joenieburg
      • Jan 2015
      cisco port-channels lookup
      Thanxs for the XML Renato,
      it helped for me to find out where my port-channels/Ether-channels are,
      Here is some info for if you only want to monitor specific port-channel and not through an discovery process,
      with snmpWalk you can read out these OID
      snmpwalk -r:{yourswitch} -v:2c -c:{public} -os:.1.3.6.1.2.1.2.2.1.2.5000 -op:.1.3.6.1.2.1.2.2.1.2.5100 -csv > thevirtualadapterlist.txt
      WIth the outcome off that list you can monitor the next oid,
      .1.3.6.1.2.1.2.2.1.5.{port_to_monitor} speed
      .1.3.6.1.2.1.2.2.1.10.{port_to_monitor} incoming octets
      .1.3.6.1.2.1.2.2.1.16.{port_to_monitor} outgoing octets
      1.3.6.1.2.1.2.2.1.8.{port_to_monitor} operator status
      And a lot more possibilities, Here I found a website from cisco where you can search for the right OID you need.
      • renato.souza
        • Nov 2015
        Hi Joenieburg,
        as a matter of fact, now I'm using the zabbix auto discover to do that.
        Get in here the new version of that template, now working and already tested for 2960, 2960c, 2960x and 3560x
