Zabbix for Log management.
  • mohammedrazal
    • Nov 2015
    Dear Team,
    We are planning to use Zabbix for Audit log management, rough about 35 GB logs will be maintained in Zabbix at any given point in time, could you please help me understanding where the logs get actually saved, Is it in DB/ Disk
    How much memory/ Disk i should forecast to accommodate this requirement.
    I implemented it successfully, now i am interested in knowing about how it exactly works.
    Thanks,
    Razal
  • zabanist
    • Jun 2015
    • 16
    I'm not really sure what you are asking. Can you give more detail of what you implemented? And what were the original requirements?
    Zabbix isn't a log management tool, so, I'm a bit confused at the beginning. It can scan log files, it can store log entries in a database, and it can write logs to syslog about internal issues...
