Win Eventlog from non canonical (from System, Application, etc. it works perfectly)
  • GlobalVision
    • Feb 2022
    • 11
    Hi everyone,
    I am new in this field and I cannot receive data from non-canonical registers (from System, Application, etc. works perfectly)
    How do I get the data from the "Kaspersky Event Log" for example?
    Since in the properties the name appears to be "Kaspersky Event Log" and the log file is "%SystemRoot% \ System32 \ Winevt \ Logs \ Kaspersky Event Log.evtx"
    I tried this but it doesn't work: eventlog [Kaspersky Event Log ,,,,,, skip]
    I believe the problem is the syntax of the name of the voice I want to log.
    Can you help me ?
    Thanks everyone!
    • 5002
    If in doubt, quote it...
    eventlog ["Kaspersky Event Log" ,,,,,, skip]
    • GlobalVision
      • Feb 2022
      • 11
      Thank you Cyber for you reply !
      I tried but it still doesn't work. Other Ideas ?
        • 5002
        Do you get item created but nothing arrives or you have problem with creating an item?
        • GlobalVision
          • Feb 2022
          • 11
          This is my item
Name:	Immagine 2022-02-16 124910.png
          But so far nothing has been received
          • GlobalVision
            • Feb 2022
            • 11
            I tried to delete and recreate it exactly as it was and now it works...
            I don't know why ?!?!
            1000 thanks for your help !!!
            • GlobalVision
              • Feb 2022
              • 11
              Sorry but after my last post I'm not receiving anything but in my PC's Event Log there are new records
              Nothing is changed and I can't understand why is not working again.
              What do you need to understand what I'm doing wrong ?
              Many thanks again
              • guille.rodriguez
                • Jun 2022
                • 120
                Check if Zabbix Agent is working on machine(agent service is running?), sometimes a few change in agent.conf may (some typo) makes service fail at start
                Check if firewall is allowing the trafic (tcp10050 from server to agent, tcp10051 from agent to server)
