Zabbix HA with corosync/pacemaker
  • joostdeheer
    • Feb 2022
    I wrote a howto for Zabbix 6.0 HA with corosync/pacemaker on OpenSUSE 15.3.
    The documentation can be downloaded here: https://www.joostdeheer.nl/zabbix/Za...nSUSE_15.3.pdf
    Please let me know if you have suggestions on how to make this better.
    Joost
  • joostdeheer
    • Feb 2022
    Ah, Zabbix 6.0 has builtin HA for the application already: https://www.zabbix.com/whats_new_6_0#ha_cluster
    • hakanozanlagan
      • Nov 2021
      • 35
      It is not a real HA solution. only frontends are being HA with zabbix solution. you can create a full HA environment including database with his method
        DB is not part of zabbix build, it is up to you, what DB to use and how to set it up. And to be precise, then its the server component what is HA. if you have frontends separately, you need to provide HA there by yourself...
