Using Macros in Calculated Items
  • adaker
    • Feb 2020
    I have a situation where I need to use a macro for a hostname in a calculated field. For example:
    last(/{$HOST_NAME}/icmpping)
    I keep getting the following error.
    Invalid parameter "/1/params": incorrect expression starting from "last(/{$HOST_NAME}/icmpping)".
    Am I doing this wrong, or is it not possible.
    Thanks in advance.
  • Answer selected by adaker at 31-03-2022, 20:41.
    cyber
    • 4985
    Shortly.. no, you cannot use user macro in such place. Would it be a constant in math operation, then yes, but for pointing to some random server it is not going to work...
      • 4985
      • PavelZ
        • Dec 2024
        • 172
        This behavior is very strange, but I found that macros can be expanded by creating calculated items dynamically using LLD rules and using Javascipt .
        A small example is here: https://github.com/pavlozt/somezabbi...affic_7.0.yaml
