Monitor Tripp-Lite UPS
  • rterio
    • Mar 2016
    I have sereral Tripp-Lite SmartOnline UPS Systems with SNMP/Web Management Accessory Card. I tried the Template_Tripplite.xml suggested in another post, but it does not extract any useful data, only up-time and the name of the UPS.
    I tried the SNMP_device template, it does extract more informations, but nothing on the batteries usage, age...
    Is there any alternative template for Tripp-Lite UPS ? Or a way to monitor more informations with the standard SNMP template ?
    Thanks for your help!
    Rene
  • LenR
    • Sep 2009
    • 1011
    Start with snmpwalk, if there is data available, Zabbix can get it.
    Start with a walk of the device, then add the enterprise OID, like
    snmpwalk -v1 -c public 10.10.10.244 .1.3.6.1.4.1
    • eophten
      • Feb 2016
      Make sure to add the MIBs for the SNMPWEBCARD to your host. You can find those MIBS here: https://www.tripplite.com/support/SNMPWEBCARD
      Once you have added those, you can use a template similar to the one I have attached. This template monitors a Tripp-Lite managed PDU for some basic data not a UPS, but it should give you an idea where to start.
