error logs messages where for LDAP authentication
  • bisana
    • Jul 2005
    • 87
    Dear All,
    I have installed Zabbix, now wants to configure it for Active directory authentication, I am trying it and get stuck, other than the pop up message where can I see the error messages in a file, when trying to connect to LDAP
    thanks
    Joseph John
  • Charlton1
    • Jun 2023
    Dear Joseph John,
    When configuring Zabbix for Active Directory authentication and encountering errors while connecting to LDAP, you can check the Zabbix server log file for detailed error messages.
    The log file is typically located in the Zabbix server installation directory under the "logs" subdirectory.
    Look for a file named "zabbix_server.log" or something similar. Open this file with a text editor and search for any entries related to LDAP or Active Directory.
    The log file should provide more information about the specific error or issue you're facing.
    If you're unable to locate the log file or need further assistance in troubleshooting the LDAP configuration, please provide more details about the specific error message or any relevant configurations you have made.
    That way, I can offer more specific guidance to help you resolve the issue.
    Best regards,
    Charlton1​
    • studero
      • Aug 2023
      • 85
      Hi all,
      I have configured the LDAP Authentification with using Active Directory server. The test authentification give a successful login.
      Then I tried to log from the login page with the same user. The page give me the following message : "Incorrect user name or password or account is temporarily blocked."
      And I do not found any think in the zabbix_server.log file.
      I need help
      Olivier
      • studero
        studero commented
        You can forget this message. I have found the solution. I do not have take the right parameters in the configuration.
