raidctl output monitoring
  • jasper9890
    • Nov 2006
    Is anyone monitoring hardware raid status on a Sun T2000 or any other machine that uses the raidctl command?
    Output is something like this below - how would you best grep or awk out the information?
    # raidctl
    RAID Volume RAID RAID Disk
    Volume Type Status Disk Status
    c1t0d0 IM OK c1t0d0 OK
    c1t1d0 OK
  • Calimero
    • Nov 2006
    • 481
    One lazy way is to monitor any change.
    In zabbix_agentd.conf
    UserParameter=raid_status,/path/to/raidctl
    Then on the Server create a new item, with Type=Character and a trigger:
    {host:raid_status.diff(0)}#0
    If anything changes in the output of raidctl, trigger goes true and you get a notification.
    Then only problem is that the trigger will only be true over a brief period.
    Of you could write a sh/php/perl/whatever script to wrap around raidctl. But this requires a bit more work.
