Monitor AdGuard Home with Zabbix
  • markfree
    • Apr 2019
    • 875
    Zabbix template for AdGuard Home​
    If you're using Zabbix to monitor your network and want to collect statistics from your AdGuard Home instance, I've created a Zabbix template that provides some useful monitoring items.
    The monitoring is agentless via a "REST-ish" API, since AdGuard Home offers an OpenAPI specification.
    It is also available for a Zabbix agent for active monitoring behind blocking systems.
    The main focus of the template is to monitor statistics from AdGuard Home, store them in the Zabbix historical database and create some observability.​
    Check it out on GitHub​
    Dashboad example:​
    Click image for larger version  Name:	dash_example1.png Views:	0 Size:	163.7 KB ID:	476732
    * It all started with a blog post by Janne Pikkarainen. Cheers to that!
  • markus.kohn.gwa
    • Oct 2022
    Great Work! Going to use it at sund-xplosion.de
