Monitor Intelbras/Dahua NVR via SNMP with Zabbix
  • markfree
    • Apr 2019
    • 875
    If you're using Zabbix to monitor your network and want to collect SNMP data from your Intelbras/Dahua NVR, I've created a Zabbix template that provides some useful monitoring items.
    Works on different NVR models from Intelbras or Dahua, although, adaptations might be required.
    Check it out on GitHub
    Dashboad example:
    Click image for larger version  Name:	grafana_dash_nvd_3316_P.png Views:	0 Size:	337.1 KB ID:	481701
  • wang
    • Aug 2025
    获取值为空能想办法解决吗
      • 5002
      Originally posted by wang
      获取值为空能想办法解决吗
      Google Translate says "Can you find a way to solve the problem of getting empty value?" - I guess you need to be more elaborate with your question...
      • markfree
        • Apr 2019
        • 875
        Indeed, more elaboration is needed.
        But I supose the referred problem is this ↗️.
