Accurate swt port descriptions with templates
  • jasper9890
    • Nov 2006
    I think i've been going about building my templates for switches wrong. Could someone share the process you went thru to get accurate switch port descriptions on graphs? Thanks!
  • triplem
    • Jun 2006
    Walk your switch with the IF-MIB (assuming your switch supports the IF-MIB):
    snmpwalk -v2c -c communityname -m IF-MIB someswitch
    You're looking for the following:
    IF-MIB::ifAlias.1
    IF-MIB::ifAlias.2
    etc...
    works fine for Cisco switches.
    from the IF-MIB.txt:
    ifAlias OBJECT-TYPE
    SYNTAX DisplayString (SIZE(0..64))
    MAX-ACCESS read-write
    STATUS current
    DESCRIPTION
    "This object is an 'alias' name for the interface as
    specified by a network manager, and provides a non-volatile
    'handle' for the interface.
    (snip)
    An example of the value which a network manager might store
    in this object for a WAN interface is the (Telco's) circuit
    number/identifier of the interface.
