monitoring ESXi 8.0 LSI RAID from zabbix using SSH
  • sciensys
    • Feb 2020
    • 20
    There is a working template for monitoring LSA Raid on ESXi 6.7 with Storcli using SSH in zabbix.
    Due to the fact that Storcli64 is already used for ESXi 8, the answers of storcli64 are different.
    For example,
    Storcli response:
    opt/lsi/storcli/storcli /c0/bbu show all j
    "Controllers":[
    "Command Status" : {
    "CLI Version" : "007.2202.0000.0000 Mar 14, 2022",
    "Operating system" : "VMkernel 6.5.0",
    "Controller" : 0,
    "Status" : "Failure",
    "Description" : "None",
    "Detailed Status" : [
    "Ctrl" : 0,
    "Status" : "Failed",
    "Property" : "-",
    "ErrMsg" : "use /cx/cv",
    "ErrCd" : 255
    and Storcli64 response:
    /opt/storcli/bin/storcli64 /c0/bbu show all j
    <?xml version="1.0"?><output xmlns:esxcli="storcli">
    <list type="string">
    <string>
    "Controllers":[
    &quot;Command Status&quot; : {
    &quot;CLI Version&quot; : &quot;007.2807.0000.0000 Dec 22, 2023&quot;,
    &quot;Operating system&quot; : &quot;VMkernel 8.0.2&quot;,
    &quot;Controller&quot; : 0,
    &quot;Status&quot; : &quot;Failure&quot;,
    &quot;Description&quot; : &quot;None&quot;,
    &quot;Detailed Status&quot; : [
    &quot;Ctrl&quot; : 0,
    &quot;Status&quot; : &quot;Failed&quot;,
    &quot;Property&quot; : &quot;-&quot;,
    &quot;ErrMsg&quot; : &quot;Battery is absent!&quot;,
    &quot;ErrCd&quot; : 34
    As you can see, nothing much has changed, except that instead of quotation marks in storсli, storсli64 now writes &quot;
    But the template is configured to process Storcli with quotation marks.
    Can anyone help me on how to quickly reconfigure processing in the template for Storcli64?​
    Maybe any other simple ideas for monitoring LSI RAID on ESXI 8.0 ?
  • PeterZielony
    • Nov 2022
    • 146
    maybe simply use replace in preprocessing
    &quot;
    to
    Click image for larger version  Name:	image.png Views:	0 Size:	7.7 KB ID:	484510
    also you would have to remove XML parts (regex?) like this:
    \{(?:[^{}]*|(?R))*\}
    with output: \0
    Click image for larger version  Name:	image.png Views:	1 Size:	13.8 KB ID:	484511
    Click image for larger version  Name:	image.png Views:	1 Size:	60.5 KB ID:	484512
    I do it slightly differently just by ssh command like this:
    /opt/lsi/storcli64/storcli64 /c0 /vall show | grep -o 'RAID5.*RW' | awk '{print $2}'
    for different RAIDs i just have different templates eg for raid 10 i have like this:
    /opt/lsi/storcli64/storcli64 /c0 /vall show | grep -o 'RAID10.*RW' | awk '{print $2}'
    returns string like this:
    "OfLn" (offline) or "Pdgd"(partially degraded) or "dgrd"(degraded) or "Optl" (Optimal)
    in either raid ver i have then value mapped to a number (simply i do replacement strings from OfLn,Pdgd,dgrd,Optl to numbers 1,2,3,4) and when number changes or is different than 4 it will trigger an alert
    Hiring in the UK? Drop a message
    • sciensys
      • Feb 2020
      • 20
      PeterZielony, thank you man, it works.
      I made path replacement from /opt/lsi/storcli/storcli -> /opt/storcli/bin/storcli64
      and all replaces in preprocessing tab as PeterZielony advise.
      reduced THROTTLING, graphic became draw
      changed trigger: LSI controller {#CTLID} cachevault battery is need to be replaced​
      (find(/Template LSI JSON discovery ssh/lsi.ctl.cvreplace.["{#CTLID}"],,"like","OK")=0 and length(last(/Template LSI JSON discovery ssh/lsi.ctl.cvreplace.["{#CTLID}"]))>0)
      Exported result in attachment.​​
      • GIL
        • Nov 2014
        • 12
        Hi all, I try to import this template to zabbix 6.4 server and get an error: Incorrect parameter "/1/username": value must be empty
        I can't find where is this parameter...
        • sciensys
          • Feb 2020
          • 20
          try .yaml
          change .xml to .yaml.
          I can't upload yaml or rar.
          .yaml slightly different syntax
