Biztalk monitoring
  • g.fernandez
    • Apr 2014
    Biztalk monitoring
    Hi all,
    Long time lurker here.
    The time to to give back all the usefull info that I get from this forum has come.
    I work on a large enviroment (~1000 hosts), that mostly has Windows virtual machines (~450 hosts).
    I have managed to create a template to LLD all windows perfcounters related to BizTalk. I use UserParameters and Windows PowerShell Scripts to retrieve the info in a JSON object to create the queries in the Zabbix Server side.
    I'll attach all the scripts that I use, zabbix agent config files and also the Template.
    Hope this helps!
    Last edited by g.fernandez; 15-03-2017, 10:27. Reason: Had to change some IPs on the config files. Privacy.
  • macao45
    • Jan 2017
    hello first of all, thank you for this work and thank you for sharing it with others.
    Having Biztalk servers, we installed the template. the different discoveries give us a list of items. but none of the discovery items give metrics.
    Do you have an idea of ​​what is missing to perform the measurements?
    best regards
