Zabbix Template for Link Quality by Simple Check
  • markfree
    • Apr 2019
    • 875
    This template provides a method for checking the reliability of multiple links. It provides simple ICMP items that give an overview of a link's connectivity, performance, and degradation. These indicators provide a basic measure of the quality and reliability of the target link. It is based on the OOTB "ICMP Ping" template and enhanced to receive a list of ICMP targets.
    A manual address list is configured to obtain the ICMP destinations, then Zabbix sends the list to an LLD rule which dynamically creates simple ICMP items for each address. It was designed primarily for Internet addresses, but can be used for most types of links, such as WAN, LAN and VPN.
    Download on GitHub
    Click image for larger version  Name:	image.png Views:	0 Size:	406.8 KB ID:	497381
  • shannan.summers
    • Mar 2025
    Any possibility you could include that dashboard in the template or a variation of it? There are a couple of widgets I can't seem to work out how to display like you have.
    • markfree
      • Apr 2019
      • 875
      This is a custom dashboard and it mixes other items from other templates.
      • markfree
        • Apr 2019
        • 875
        I've added a template dashboard to make it easier to keep track of network target links. Check out the new version on GitHub.
        The Zabbix template dashboard is quite limited for item prototypes, so this dashboard is based on the discovery rule graph prototypes. A simple graph for each link.
        It is still recommended to add your custom dashboard to the main Zabbix dashboard panel.
