Zabbix Template for Citrix NetScaler ADC
  • markfree
    • Apr 2019
    • 875
    This template template allows you to quickly capture the key metrics of the Citrix NetScaler load-balancers. As the instances change, the monitoring is automatically updated. The metrics history also allows you to observe the behavior and trends of the key indicators.
    Two independent templates are included with two monitoring methods, one for passive data collection via SNMP and another for active SNMP Trap capture. This way of organizing both methods simplifies the management of monitored items.
    ↗️ Download on GitHub
    Feedbacks are very welcome.
  • markfree
    • Apr 2019
    • 875
    Major update released for this template following version 7.4.12. Check the GitHub above.
