Zabbix monitoring Deye inverter over Deye Stick Logger LSE-3
  • piton4ik
    • Nov 2024
    • 17
    Hi all, i need monitoring my Deye SUN-30K-SG01HP3 and Deye SUN-6K-SG03LP1-EU
    i make template use modbus.get,
    help update template to make surveys better and more efficient than they are now, maybe I'm not using all the functionality of zabbix
    set ip addres in host settings on tab Macros
    Deye-LV-Invertor-Sun6k-hosts.yaml
    Deye-HV-Invertor-Sun30k-hosts.yaml
    Deye-LV-Inverter-MODBUS-TCP-template.yaml
    Deye-HV-Inverter-MODBUS-TCP-template.yaml
    Contribute to piton4iksh/zabbix-deye-inverter development by creating an account on GitHub.
    created Zabbix 7.2.3. © 2001–2025, Zabbix SIA
  • orbital
    • Dec 2019
    • 106
    Hi, I have this inverter - SUN-6K-SG03LP1-EU. I added your template, entered the IP address and port, but I'm still not receiving data. Is there anything else I need to enter?
    • piton4ik
      • Nov 2024
      • 17
      You use WiFi or ethernet deye stick loger?
      In my example I use ethernet logger
      • orbital
        orbital commented
        I use WiFi logger. It's not connected to the official cloud, but it works great with the local Home Assistant.
    • piton4ik
      • Nov 2024
      • 17
      You need edit IP only, port is static for all stick logger
