Monitoring VMware snapshots
  • Muteone
    • Nov 2025
    Hi everyone, I have a custom PowerShell script someone wrote at my work to check for snapshots on VMware vms but I'd like to have this in zabbix, has anyone done this?
    Thanks,
  • mariusl
    • Aug 2024
    • 33
    Why don't you use the built in VMWare functionality?
    • Muteone
      • Nov 2025
      I am, there's no snapshot items in the templates.
      • Jason
        • Nov 2007
        • 431
        How about https://www.zabbix.com/documentation...re.vm.snapshot ?
        • Muteone
          • Nov 2025
          I've made a template, struggling to get alerts to ignore Veeam snapshots and only show old snapshots.
          • Jason
            Jason commented
            Can you parse createtime to a datetime field and get age of that as difference from now?
        • Muteone
          • Nov 2025
          Got something working, I wanted multiple items in the trigger expression so I could show them in operational data.
          The main issue I was having was trying to filter out Veeam snapshots, this is done on the master item now as an exclusion array.
          The second issue was the time needing to be converted to epoch
          There was a final issue of alerts not resolving as the values became empty when the snapshot was removed so I had to add values on JSON lookup failure.
          Still some fine tuning to do.
          I just linked this to the existing vmware guest template
          EDIT: Code deleted to avoid perma ban.
          Last edited by Muteone; 14-11-2025, 01:13. Reason: Don't want to be banned for sharing my work.
          • Jason
            • Nov 2007
            • 431
            If you use a discovery based on the JSON string from snapshot.get (do the discovery and items based on dependent items) then it should work and auto clear items when then the snapshots go. Then it should be fairly easy to filter out the snapshot names to remove the veeam ones.
            • k-hole
              • Aug 2022
              • 10
